Question about Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
Sewpro quick stitch 407 - Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
What way are we supposed to put in the replacement needle in a singer stitch sew quick machine? The loop stitch isn't looping
The needle should be inserted so that the flat side faces the front of the Sew Quick. (The flat side should face the set screw that secures the needle in the Sew Quick.) See figure 11 (on page 2) of the manual. One link to the manual is currently: http://www.hayneedle.com/images/PDF/MICL002.pdf . Make sure that you are using the DHx1 needle.
If the stitches still aren't looping, make sure that you have threaded the needle and bobbin correctly. The thread should start at the back of the needle and be pulled to the front.
I hope this helps.
Aug 17, 2016 | Singer Sewing Machines
Stitch length will not change
Setting Stitch Length: A Quick Look at How and Why ...
www.sew4home.com/.../sewing.../setting-stitch-length-quick-look-how-a...
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
How to Select Stitch Length ' Sewing Lessons - YouTube
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Jan 24, 2016 | Sewing Machines
Where can i buy a spool pin attachment piece for a sewpro quick stitch
Check with a local sewing machine repair service who may have one or be able to find one for you.
Nov 17, 2015 | Sewing Machines
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Sew Pro QuickStitch SP-402 Mechanical Sewing Machine Logo
22 people viewed this question
Top Sew Pro Sewing Machines Experts
Steve
ray gallant
Debbie
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
