Question about Dewalt DW621 Routers
It won't start or run all of a suddent
Not a brand new model but I have not used it very much. But enough to know how to make it run and it quit on me in the middle of a job. Is there any kind of fix or reset that I am unable to see?
  • 3 Answers
Take it apart and check the electrical connections and brushes. Check the power cord and be sure you are getting power to the connections at the motor switch. If yes, turn switch on. Are you getting power off the other side of the switch. If you don't see any issues with those it may be time to take to the shop.
Posted on Apr 24, 2009
Have put new fuel pump on ,cleaned carb,new plug, gets gas plug fires but won't start, checked compression at98# don't know what else to do .
The battery voltage on a Suzuki I had would drop low enough during cranking with the electric starter motor not allowing the spark to be strong enough to run, the voltage regulator also didn't function correctly once and as the battery voltage dropped during operation engine would start to bog down and cut out due to low voltage for the ignition system.
Jul 18, 2013 | ATVs
Car cold, won't idle. Right. Starts then quit
not specific enough, what kind of car? Year? Make and model could be multiple reasons for these symptoms. Could be something simple that needs service such as the Idle Air Control Valve
Jan 04, 2013 | Cars & Trucks
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
1987 300 zx starts the quits after 2 minutes and won't start again
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
Oct 28, 2011 | 1987 Nissan 300ZX
Started engine prior to hurricane season . It seems to run good only in choke , adjust toward run and it quits!! thanks
If it only ran good with choke then that means the engine is running too lean and not getting enough fuel. You need to remove, fully disassemble, and thoroughly clean the carb. Or you could also just install a brand new carb if you don't have experience working on carburetors.
Jul 17, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
Weed wacker runs then quits and won't start for hours
Sounds as if the issue is related to heat. Possible ignition failure when hot. (I see that alot in my shop.) If the unit is new take it to an AUTHORIZED repair shop and it should cost you nothing. Locate your nearest repair shop HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
Dewalt DW621 Routers Logo
336 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
