Question about Electrolux Centralux Vacuum
My central vacuum was running for a minute and then it stopped on its own. i went out to the garage to see if the breaker had tripped and i reset it and can not get it to turn on again..
2 Suggested Answers
  • 4 Answers
SOURCE: Electrolux Central Vacuum won't turn off
There is a relay board on the unit (where the dirt goes) There are two small wires that connect and usually a switch near by. This switch has an Auto and Manual setting. If set to manual the unit will run all the time or until set back to Auto. If it is set to Auto and is still running, unplig the two small wires. They are sometimes on screw terminals behind a round plactic cover. It does not matter which terminal the wires go back on just one on each.
If the unit turns off the problem is in the wire running to each valve or a paper clip is shorting across the pins of a wall outlet. (something like this).
If the unit does not turn off once the wires are removed, the relay in the unit is stuck closed and will need to be replaced. Time to call a pro unless you have good electrical skills.
Hope this helps!
VR
Posted on Nov 18, 2008
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
It seems stopped up. Picked up pieces of styrofoam
If the Rainbow kept running but the power nozzle stopped, it could be the Circuit Breaker PN2E PN2 that tripped. Try resetting to see if that fixes problem.
If the Rainbow stopped running, the auto reset could have tripped. Wait about an hour to see if it resets.
Our tech. team is available if needed... Contact Us
RainVac
May 08, 2014 | Rainbow E series Canister Wet/Dry Vacuum
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
Central vacuum with new motor shuts off and throws switch
Your mini breaker is probably bad if its a new motor. Its found on the relay board and they can weaken over time, especially if you had a bad motor before that tripped it a lot.
Oct 31, 2009 | Vacuums
The breaker on the vacuum trips after about 3 seconds on. The canister was extremely full and started to smell like burnt wood, we fully cleaned out the unit. Now when the vacuum is turned on, the motor...
This sounds indicative of a worn set of carbon brushes on a dieing motor for a central vac. the armature is ,likely damaged causing teh breaker to blow. Please post back with more details as to make and model. Do not atempt to run the vac
Sep 27, 2009 | Vacuums
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Nutone cv353 central vac blew up
My guess would be that the motor is done. Impossible to diagnose for sure without seeing it of course. If you were happy with the unit before the trouble, a replacement motor will probably run $250-$300. If you are interested in a new unit, shop around. There are definitely better designed and more powerful units out there, although some of them can cost quite a bit more than $300. Good Luck!!
Dec 14, 2008 | Broan-NuTone CV353 Central Vacuum
Nutone cv750 problem
I doubt that's an electrical breaker - because it wouldn't take 10 minutes to flip, it would happen almost immediately. It must be the heat breaker. There are two reasons your vacuum system could be overheating and tripping that breaker. Either you need to replace the filter - if it's partially clogged then the motor may have to work too hard to get suction and cause it to overheat. I'd suggest checking the filter first, because that's the easy fix. If it's not the filter, then your motor is going out. You'll want to replace that. Check the filter, and let me know. I'll see if I can find a place to order a new motor for it.
Sep 01, 2007 | Broan-NuTone CV570 Central Bagless Central...
Electrolux Centralux Vacuum Logo
15 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
