Question about Sony Playstation 3 (PS3) Console
Playstation 3 no visual display to tv
Let it to my mate how has hdtv he changed the settings and now it wont show a picture on my normal scart tv. please help
Simple mate. When your loading up the playstation, hold the power button, until you hear the second beep, and it should restore to it's original settings.
Posted on Apr 24, 2009
Woodford provided the corect answser
The picture quality on my Sanyo LED-42XR10FH TV has changed since I added my Playstation 3. Picture is juddery and appears to be dropping frames. This happens while watching normal TV as well, not jus
should be an 'input' button or some variation of the name on the remote.
or
Copied directly from the Sony website:
Perform the following steps to reset the Video Output Settings.
Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system.
Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If resetting does not auto-detect your HDTV, see next step below.
Oct 05, 2017 | Televison & Video
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
I can not see any picture or sound at all. We have the HDMI cable pluged in the PS3 and the TV, but red white ,and yellow plugs we r not sure where they should be.
There are different settings for PS3 video output, i.e. if it is set for HDMI it wont display when a scart lead is used. Try the scart connector, if it works go into settings and change to how you want it set, dont forget to save settings
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
It is switched on all cables are inserted but no picture on tv
wich cables are you using ? if the console was connected to HDMI it wont display anything on SCART until you manually configured it back to SCART
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
Playstation doesnt display at all
hold the power button until it blink twice then turn off.
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 connection
If I remember correctly the Playstation 3 is set to display through the analog output as default.
Plug in your HDMI cable, and plug in the analog SCART cable that came with the box, put your TV on the analog channel that matches the SCART input and start the Playstation. Once you complete the initial Playstation setup you can go to system settings and change the video output from analog SCART to digital HDMI.
Good luck.
Jan 31, 2009 | Video Game Consoles & Games
PS3 Scart / HD
Turn it off with the "hard" switch in the back. Then turn it back on with the switch while pressing the power button on the front for 10 secs, this should reset your display settings.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Hd to normal tv problems
i had the same problem, but the reset worked for me, hold down the power button until u hear the "beep"
Apr 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont show up on TV
you will have to find an hdtv to change it back.
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
