Question about Motorola Computers & Internet
Hello: I would like to know if the Motorola
Hello: I would like to know if the Motorola SB6121 cable modem is made to work with Windows 8. I looked at one and also the SB6141 at our local Wal-Mart and noticed that the SB6141 said Windows 8 compatible on the box but the SB6121 made no mention of being compatible. I have a Dell Inspiron 660s desktop with Windows 8 and I'm going to use Time Warner cable as the internet service provider. The SB6121 is less expensive than the SB6141 so I'm hoping to save a little money. Thanks for any reply.
    Sergeant:
  • 238 Answers
Yes, it's theoretically slower, but that depends on your connection. Which to Buy the Arris Motorola SB6141 or SB6121
Posted on May 25, 2017
SOURCE: modem cable Motorola SB 4100
TM-IP5600Motorola
Posted on Apr 16, 2008
frcs68
  • 1605 Answers
SOURCE: Verizon DSL spotty service
to answer your first question, call verizon to fix the line. it is dropping. Second have verizon change a dsl and test it out.
as far as the tab on the CAT-5, the tab is to lock the cable in place, without it, it will work but you have no insurace as to the connection status. (need cable with tab).
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
Posted on May 04, 2009
  • 83 Answers
SOURCE: Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
Posted on May 20, 2009
  • 23 Answers
SOURCE: Hi, I’m facing one issue with D-Link (DCM-202)
Is this a new issue or a recent harware/cable change or did this use to work and now has the disconnect issues.
Ensure that your cable has NO Splitters (especialy outside) from the Drop outside to your modem.
Check all cableing between Computer and Modem to Cable Drop.
You can also look at the Modem Status Page to check your UpStream and DownStream signals. You may have to have someone come out to check out the line running from your house to the pole (or pedestal if its underground)? Many factors can cause an outside cable to deteriorate, and when that happens you can end up with alot of signal leakage and frequent disconnects. And that goes for both overhead and underground lines. Good Luck, and post back if you need more help. (try to include your Modem Status Logs)
Posted on Jan 02, 2011
Will motorola Sb6140 work with century link internet
centurylink looks like its dsl (which uses a home phone) ppoe
comcast uses cable connection (like cable tv) don't think their compatible
call centurylink to be sure
Feb 22, 2016 | Arris Surfboard Extreme Sb-6121 Docsis 3.0...
Is there a WPS button on my Motorola SB6121 Modem?
I don't see it in the picture searching, but if this function will be able, you will see special button for it somewhere on your modem.
Feb 19, 2015 | Motorola Computers & Internet
How do I find the bridge mode in sb6121
The Motorola Surfboard SB6121 is a cable modem only - no router included.
You must have a router - after the modem - in the network if you need router duties.
There is no bridge mode in the modem. Bridging the modem basically bypasses the routing function of the device and passes everything on to the next device in line......the router in this case.
Since this modem does not have a router built in - it is always in bridge mode.
Feb 03, 2015 | Arris Sb6121 Docsis 3.0 Cable Modem...
Why is the power and internet led white?
For troubleshooting it is best to contact ARRIS
Mark
Motorola Support
Aug 17, 2014 | Arris Surfboard Extreme Sb-6121 Docsis 3.0...
Why Motorolla SB6121 receive light won't steady
Contact ARRIS might be that it cannot link up properly. A comcast tech might need to come out and check it.
Jul 08, 2014 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
SURFboard DOCSIS 3.0 boosting the wifi signal
The SB6121 doesn't have WiFi, but I used a wifi extender (~$40-$80) to boost the wifi signal of my current wireless router that's attached to the SB6121.
Sep 20, 2013 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Nov 06, 2012 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
Does the motorola sb6121 have a router built in?
Well, I'm not sure exactly what you mean by router, but I can tell you that it only has one physical ethernet port, not 3 or 4. It does have a built-in DHCP server, which means that if you have more than one computer connecting through it (using a wireless access point, for instance), it can assign each of them a separate IP address. The setup guide is here:http://www.motorola.com/staticfiles/Video-Solutions/Products/Voice-and-Data-CPE/DOCSIS-Modems-Gateways-and-eMTAs/Cable-Modems/SB6121/_Documents/_StaticFiles/577212-001-a.pdf
Jan 28, 2012 | Motorola SURFboard Computers & Internet
Computers & Internet Logo
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
