Question about Jura Capresso 560 Electric Burr Grinder
Parts capresso timer dial broken can it be replaced?
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Clock generator dial
If this is Woods timer, then there are no replacement parts.
I am not familiar with KMD as a model number or brand.
Copy following link to identify same-similar timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add comment and describe timer in detail or attach photo.
The only timers on market today with replacement parts are Intermatic. And some Tork.
http://waterheatertimer.org/intermatic-timers-and-manuals.html
http://waterheatertimer.org/intermatic-trippers-and-parts.html#T100
Gene
k
Aug 05, 2013 | Coleman Cable Woods 59402 40Amp Timer for...
My timer keeps turning my pump on and off randomly. Is there a repair kit available to replace whatever worn/weak parts have gone out?
Intermatic has repair parts that are sold by model number of timer.
Suspects include loose wiring, bad circuit breaker, bad timer clock motor, bad timer.
1) Key things to check are loose-or-burned wires, manual override lever operation, and clock dial rotation.
If you have T104, then test across terminals 1 and 3 for 240Volts.
For example if manual override lever is broken and loose, then buy timer mechanism without replacing box. If clock is not rotating correctly, then check electrical circuit and/or buy clock motor.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
2) Open following link to see list of parts.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
Apparently, the spring under the timer dial on my 4001 timer has been broken and the timer will no longer trip the trippers. Can this be fixed? It is a nearly-new unit and I like it.
Open following link for Paragon resources:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Individual parts are not sold except for X2772 tripper.
Move the manual override lever back and forth and see if load turns on-off.
Watch if on-and-off trippers are moving override lever back and forth, to see if problem is a worn tripper instead of broken spring.
Replacement 4001-00 timers are sold, even though Paragon is no longer making timers except defrost timers.
http://www.mdappliance.com/RBS-4001-00.html?mv_pc=00015
Replacement timer is Intermatic T101
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jun 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Lights come on but don't stay on even though the tabs are set for it to stay on say from 4-12 it will go off at 7:30. Someone got thier hands on this before i did---could the tabs have been broken if...
GM40 is commercial-grade electronic time piece with FM1 analog timer dial.
I bought a used GM40 once and the electronics were bad, so if this is a used timer, it might not function as expected.
I don't think the tabs/pins are broken. FM1 timer module is heavy duty.
Turning the dial clockwise does not damage timer. That's how you set current time and test timer.
Rotating dial counterclockwise is not possible without breaking the timer.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/pdf/Intermatic-Grasslin-gm40.pdf
FM1 analog timer module can be replaced if timer stopped working.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
If certain pins/tabs are broken, you might be able to work around problem by offsetting current time by 6 hours or 12 hours. Or you can move wires from NO to NC terminals and see if the relays are causing a problem.
To set FM1 timer, the pins are pushed outward or inward.
For example to turn on Load for 1 hour, then 4 consecutive pins are moved.
To turn on Load for 3 hours, then 12 consecutive pins are moved.
To test if pins need to be inward or outward, set some pins and then manually rotate timer dial clockwise and watch when the Load turns on-off.
Jun 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I have a broken wash cycle timer knob on my whirlpool LTE5243BN0 thin twin washer/dryer. Ordered a replacement part, looks the same as my old one, threads okay, can't seem to screw it all the way on. The...
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
Oct 01, 2017 | Whirlpool LTE5243D Top Load Stacked...
I need instructions on how to use the GE Ge 15107 24Hour Yard Stake Timer
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
Oct 21, 2010 | GE 15107 24Hour Yard Stake Timer
Jura F9-inside part fell off while pulling the tray. Cannot fix.
Kris I have this same problem. Did you figure out how to replace the flap or did you have to take it in for repair.
Does anyone else know how to replace this plastic flap?
Feb 24, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso 560 Electric Burr Grinder Logo
232 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
