Question about KitchenAid Dryers
Kitchenaid dryer super capacity plus
Dryer runs but no longer heats
  • 21 Answers
SOURCE: dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Posted on Dec 26, 2008
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
  • 14 Answers
SOURCE: ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
Posted on May 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 06, 2009
ginko
  • 19396 Answers
SOURCE: I have an Estate heavy
Hi.
Check thermal fuse. After that check the thermostats and finally the element. In your case the Whirlpool built Super Capacity has two thermal switches located in the heater box and a cycling thermostat. If replacing thermal fuse did not do the job, test the thermostats for continuity using a multimeter. Additionally to the three thermostats mentioned before , there is an high-limit thermostat. See the diagram below to locate parts. If any of the thermostats is open at room temperature (it reads infinity), replace the part. Heating element is also tested checking continuity.
After repairing, remove all lint from air ducts, that is the primary cause for overheating. Ensure also that the fan is working. If fan is not working the thermostats will blow.
Here diagram, click on picture to enlarge:
  • Thermal fuse is part 7.
  • Thermal limiters part 8.
  • Cycling thermostat is part 9
  • High limit part 15
  • Heating element is part 17.
Here an article explaining how to troubleshoot the problem.
Here parts and diagrams for one of the Super Capacity Plus dryers: WED5300SQ0, enter your own model number in part seller page to be sure that you order the right part.
Regards.
Ginko
Posted on May 16, 2011
My dryer anit heating up but it runs?
Your thermal cut out relay may be bad, your heating coil may be bad, but be sure to check lint filter and the vent pipe before checking the thermal cut out and heating element
Aug 20, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer run but does not heat
Chedk your breakers the dryer will run on 110v but wont heat
Nov 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Cabrio Dryer WED5500XWO not heating up
Is dryer conrtolled by 2 breakers ,if so one is for heat the other for power.
Jan 29, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Runs but no heat
What is the model number of the unit?
Nov 29, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
We have an older dryer (ultimate care - super plus capacity) 12+ years old. It no longer "heats". Drum is still turning. I am assuming it is a thermostat - how much do those cost to repair?...
When it doesn't heat it could range from the timer to the heat element to the thermostat or even the motor so it could be as little as $125-350 to repair.
Aug 12, 2011 | Whirlpool Dryers
Dryer runs but will not get hot
hi crich... generally when the dryer will not get hot the heating element is bad and must be replaced. Joe
Thanks for choosing Fixya!1
Feb 24, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer run until it heats up and then stops and all the light on the display goes out.
the thermis is over heating this could be a faulty sensor or it is getting too hot from the motor first have the elements thermistat checked
Jan 06, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Takes three cycles to dry towels; i checked the venting but it goes up to roof so how do know if its blocked further up? My house is 5yrs old
usually long dry times is a restricted vent.. most vent are a straight shot out the back with longer vents excess buildup is common... unplug the vent in the back to the dryer and run a load if it heats quicker then u know ur venting is clogged up... hope this helps
Jan 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Open Questions:
Dryers Logo
21 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
