Question about Sony CMT-EP707 CD Shelf System
Cd doors don't open and Errors 1 and 4 - Sony CMT-EP707 CD Shelf System
When I had the same problem with my CMT-EP707, I used a variation of the first approach above. I turned off the unit, then turned it back on while holding down the eject button (and maybe the stop button too) for each of the CD trays in turn. When I did that for the CD tray 2, it ejected, even though the error was on #1. Once #2 ejected, the other two began working too.
Posted on Dec 18, 2009
Try this first:
Unplug power cord, on the corresponding drawer, push open/close and stop at the same time and hold them in. While holding the buttons in, insert power cord.
This unlocks the drawer if it is the security mode
Try this second:
1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor.
2. Check for broken or loose gears and have them replaced.
3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players.
4. Use electronics-grade contact cleaner to clean the door-position contacts
Posted on Apr 23, 2009
2 Suggested Answers
SOURCE: cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer Ā· CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
How do I open a cassette door that is stuck?
problem in belt
rotuate fly wheel door is open
Apr 28, 2014 | Sharp CD-BA250 CD Shelf System
I have 2 lift master garage door openers that are producing errors when you hit the buttons to open 2 different doors. 1. I get error code 11 (sensor blocked or miswired)-there is nothing blocking...
If your garage door is up, and you break the beam (by walking through it, for example), you will get the "SENSOR WIRING INTERMITTENT CONNECTION ERROR CODE 1-4 SEE USER MANUAL". This is normal. Both of my Liftmaster 8550 openers do this. It's misleading, but this is what I've found to cause this error.
Oct 29, 2013 | liftmaster Lift Master 377LM 376LM 315 MHz...
Cd door wont open
if u can here the motor buzz trying to open it, then it might just be off the track
if it don't buzz, the motor is dead
Aug 22, 2012 | Audio Players & Recorders
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
A cd is stuck in my laptop the door opens but no cd
might be stuck inside(this is NOT a good thing)
open tray
peer in side and see if there's a cd deep inside(if not then it's a dirty lens..clean) OR a bad cd reader(they don't really last that long
Jun 02, 2012 | Lenovo Computers & Internet
How to eject cd from dell inspiron
Press the button the cd drive door or click Start/My Computer then Right Click on the CD Drive and select EJECT.
If it is stuck you will need to take a Paper Clip (Gem Clip) and straighten it out. Then look for the tiny hole on the CD Drive door and push the Paper Clip (Gem Clip) into the hole and Press the the button on the drive door. As you Press the button on the drive door, push the paper clip in and the door will pop open.
Don't worry about breaking something, that is why the tiny hole is there.
May 04, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
Sony CMT-EP707 CD Shelf System Logo
561 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
