Fax machine beeping - Samsung SF5100
Fax machine keeps beeping since reconnecting phone line - one beep sounding like a fax is coming thru, but none appear. No problem receivng faxes - noise driving PA mad
  • 1 more comment
  • cvelim Sep 26, 2007
    1. dial tone - yes
    2. incoming calls now set to 1 ring (it is a dedicated fax line)
    3. dont know what a DRPD is - can you pl explain?
    4. have cleared memory as suggested
    5. faxes are being received OK
    6. machine bleeps just once - as tho a fax is incoming - nothing more happens
    7. your help much appreciated, but problem persists
    line is OK
  • cvelim Oct 01, 2007
    tried everything suggested - problem persists
    thanks anyway
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Posted on Sep 25, 2007
  • HEMANT GROVER Sep 26, 2007
    THANKS FOR YR OBSERVATIONS,PLEASE PUT ANOTHER TELEPHONE LINE TO CROSS CHECK WHETHER LINE IS OK OR NOT.
    OMNIPRESENT
MY HP Fax machine won't send fax, sends error what is wrong with the machine it's a 2007 Model 1040. when I am sending the fax after one page it beeps a lot and then feeds the rest of the pages. then on...
You either have a noisy or Digital phone line.
Have your phone company check the line.
I have NEVER seen a bad fax modem, unless it was fried by a lightning strike.
Apr 28, 2010 | Office Equipment & Supplies
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
Samsung sf5100 fax How do i replace the toner
Open front cover,then pull out toner and in the middle you will see a tiny fuse. Take it out and put a new one in. Put back toner,close everything and let it run.
Sep 11, 2009 | Samsung SF-5100 Plain Paper Laser Fax
WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
Fax beeping after a message was sent out.
It means it never found a dial tone. Check the line with a regular phone.
Jan 26, 2009 | Office Equipment & Supplies
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Samsung SF 6800
USE THE SILENT MODE.. HAPPY FAXING OMNIPRESENT
May 08, 2007 | Samsung SF-6800 Plain Paper Laser Fax
776 people viewed this question
k24674
jasbo
jasbo
