Question about John Deere Garden
John Deere f735 diesel riding mower
When you crank it it will not stay running it cuts off
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Posted on Jun 21, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
6ylucy
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
I have a John Deere F735 99 model want start,has fuel to pump but fuel shut off solenoid not pulling in
find the reason for the solenoid not working and you have the answer to the problem
May 13, 2016 | John Deere Garden
I have a john deere f735 diesel cant get power to fiel pump
bad ignition switch or wire any inline fuse?
Apr 15, 2015 | John Deere Garden
Why does my john deere 997z diesel cut off after only mowing 30 to 45 min ? It will crank back but cut right back off it has to sit a couple of days to run again
check for water in diesil change fuel filter see if that take care of it the next thing put a ignition coil on it, or then do valve job for damaged valves
Sep 03, 2014 | John Deere Garden
Stx 30 Starts, runs until attempt to engage electric clutch.Thanks
I have a John Deere STX30. I can start it, but when engage into gear it die completely!
Jul 06, 2011 | John Deere Lawn Tractor Seat F710 F725...
I need a diagram that shows me how to replace the belt on my F725 front deck john deer mower
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
Apr 29, 2011 | John Deere Seat For F710 F725 F735 Riding...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
