Question about Cycling
SHIMANO ALTUS ST-EF51 EZ FIRE PLUS 7 SPEED SHIFTERS wont shift gear
3 Suggested Answers
  • 61 Answers
SOURCE: shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Posted on Nov 22, 2009
  • 4 Answers
SOURCE: ST EF20 SHIMANO right
Remove the top plastic cover secured by two small screws
-At first glance you'll only notice half of the gears teeth, and as you shift the lever it will apear that the lever's push will bottom out and will not shift past the 4th or 5th gear.
- If you look close with a light you will see that teeth run completely along the entire gear and the teeth get super small just before the biggest tooth of the gear.
-the problem is that the shifter's cam (hooked lever) aka engager is seized and cannot swing into and bite into the smaller teeth.
-With some lube or even wd-40 spray the engager and exercise it with a small screwdriver so it can loosen up and spring into the small teeth.
-Start shifting and releasing several times to work the the lube in
- Install the cover and you're done!
Posted on Nov 03, 2011
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
How do i dial in shimano 7 speed thumb shift to rear derailleur
Put chain on the "road" gear, Usually #7. Set shifter the same. Cable should be tight, but not forcing it to the next gear. Loosen adjustment, tighten cable and try. It may take several; tries.
Aug 24, 2014 | Cycling
How to instal front gear cable trigger shifter on a womens 7.2 fx bicycle
Does this Trek model have the Shimano EF51, E-Z Fire 8 speed shifter fitted?
Are you replacing it?
Jun 16, 2013 | Cycling
1 have a mid 90's bike with a Shimano Acera X that will not shift
My solution on the same shifters was to lube the grippers on the levers, they did not engage but after moving them around and lubing they started to grip and problem fixed.
Apr 25, 2010 | Cycling
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
Mountain bike advise
sounds like a pretty good bike for what you will be using it for
Oct 22, 2009 | Cycling
Shimano Altus gears
The old lubricant has gummed up. It needs a good cleaning and relubrication.
"STI shifters gum up after years of use. I've had good luck with this method and since it's nearly free it's probably worth a shot--
"Get a can of WD-40 or a similar light solvent/oil solution. Pull the brake lever back to the bar to partially expose the shifting mechanism and generously hose down the interior with your solvent. I mean really get it in there from all directions, using the little red spray tube if possible. Let it sit for a while and then drizzle in some light oil like Tri-Flo or similar. Then wipe down the exterior of the shifter with some Simple Green or other degreaser (to keep the overspray off your hands).
"I've rescued two sets of STI-type shifters with this method. Hope you get your problem solved one way or another, because new Dura-Ace sure ain't cheap."
source: http://www.bikeforums.net/archive/index.php/t-83743.html
Jun 25, 2009 | Mountain Shimano Altus Front Bike...
Cycling Logo
41 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
