Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Need manuel for craftsman chain saw 2.0 358 352 690 16" PS
3 Suggested Answers
SOURCE: I have a craftsman gas chain saw model 358.352180....
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
Posted on Jun 18, 2010
guythegrilla
  • 21 Answers
SOURCE: fuel lines on a craftsman chain saw need to be
just connect them both anyway you chose. press prime button a few times to pressurise tank. you get a 50/50 chance to get it right.
if it just sucking air release pressure first by removing filler cap to prevent face full of fuel then swap pipes over on carb. i did this job a couple of weeks a go on my husky66. only use proper flexy pipe from a lawn mower centre. costs about £2.50 / foot.
Posted on Aug 12, 2010
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
Need a manual for a 14" Craftsman electric chain
Use model number 315.34020 which is the same saw w/o power sharp. In fact the 34030 model is mentioned in this manual. I haven't found anything relating to the 34030 model specifically. Oregon products is able to cross reference the saw and find parts for it (less the power sharp feature.)
Jan 02, 2011 | Craftsman Garden
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
10 year old craftsman chain saw14 or 16 inch sears craftsman
Duplicate Post
There is usually a sticker with a craftsman Model Number on it, often "358.Something". That number can be used to find an IPL and if you are lucky an OM here: Sears PartsDirect http://www.searspartsdirect.com/partsdirect/index.action Start at 1.5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Duplicate Answer
Feb 19, 2010 | Homelite Garden
What oil do i use for Craftsman Chain Saw 16'' 3.5 peak electric
any brand bar&chain oil will work the lighter weight oil is best for your electric saw.like 20 weight.
Nov 04, 2009 | Exercise & Fitness
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Mar 26, 2009 | Garden
Looking for scroll saw manuel
Go to Searspartsdirect.com and type in your model number. I checked and also found that a lot of parts for this saw are discontinued so good luck.
Dec 04, 2008 | Saws
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
29 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
