Question about Refrigerators
Changed water filter red light stays on
  • rablterrell Apr 30, 2009
    I changed the filter but the light is still on. How do you get it to go off??
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Posted on Jun 01, 2009
I know on my KitchenAid (different model), you need to reset the light by pressing the Water Filter button 5 times. The light should then change from red to green.
Posted on May 02, 2009
When you hold down lock auto light it turns off all the indicator lights completely. To sufficiently reset the filter to "green" hold down the lock water buttons at the same time for about 15 secs
Posted on Apr 27, 2011
On a Frigidaire Superba I had changed the filter and the reset button was stuck on red. So, I held the Lock Button on the front door down while pushing the change filter light down and it 'CLICKED' and went from 'Change' to 'Good'.
Posted on Aug 02, 2009
  • 1314 Answers
SOURCE: Water filter alarm light
without the specifc model number i beleive you hold down the button under the filter light to clear it i think its a hidden button right under the light but if not send me the model num and ill look it up
Posted on Jan 09, 2008
  • 44 Answers
SOURCE: changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
Posted on May 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: red light stays on after changing the water filter
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Posted on Nov 27, 2009
Testimonial: "Great, Thanks"
hh0405
  • 77 Answers
SOURCE: Change water filter indicater light
press and hold the filter button for 5 second the light will go green
Posted on Apr 11, 2010
toolkits
  • 1099 Answers
SOURCE: Please tell me how to
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Take care......
Posted on Aug 13, 2010
Green alarm light continuously on. Any ideas?
Green light usually means your water filter is in great condition . the light will stay on,over time change to amber then red. Red means change filter
Jul 22, 2015 | Refrigerators
Frigidaire filter status light will not reset
Check to be sure your water source is on. Low pressure may make the filter sensor think there is a plugged filter.
Mar 17, 2014 | Frigidaire Refrigerators
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
On this Frigidaire water filter system, there is a filter state light, wich was red when i bougth the frige second-hand, changed to green, when i changed the filter, normal, but it stays green, even after...
HI, if yours is similar to mine with ice maker and gets used several times a day my light comes on about every 6 mo. but i do have three kids so i use a lot of water. depending on use it could last 11 mos. but i would not go past a year if not used as much.
Mar 12, 2011 | Refrigerators
Red light stays on after changing the water filter and running about 2 gallons through it
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
How often should you have to change the water filter?
Only replace the filter when water flow diminishes or ice cubes get visibly smaller , not when red light comes on .
Aug 06, 2009 | Refrigerators
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
2,491 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
