Question about Kenwood KDC-MP535U CD Player
Kdc mp535u overheats
I just bought this thing and about 15 minutes into listening to it the heatsink gets really hot, the volume without actually turning it down, infact i can turn it up, but the volume gets lower and lower eventually gets staticky then turns off. the radio stays on and is fully functional volume knob and all, and if i turn on my A/C it will cool off for a minute ill get music then back to nothing. No error msg, or protect. its hooked up correctly (same as my last 2 stereo's)what could cause it?
I have the same unit, but my "Aux-in" no longer works.. help.
Posted on Nov 19, 2008
Handy?  Did you find a  solution? if so please tell me, mine doing [email protected]
Posted on Oct 24, 2007
SOURCE:
Volume decreases drasticly when playing fairly loud for 15-20 minutes
You're probably overdriving the amplifier, meaning the speakers are sucking up more power than the amplifier is capable of. When you turn it up loud it overheats and causes the system to go into a protect mode so it doesn't catch on fire (yes... it happens!). Make sure your system is capable of handling the power needs of your speakers. And don't burn your house down! I had a high-end Harmon-Kardon receiver burst into flames. It's a good thing I was standing next to it or my house would have been toast.
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
Volume decreases drasticly after playing loud 15-20minutes
Shes overheating and thus goes into emergency mode and shuts down the volume to help cool down the built in amp . Dont know if it has a built in fan (likely not) but its overheating which can be a number of reasons why...from a failed heatsink componet, inadequet venting, shorted circuit. Can you take it out and inspect it?
Acer Extensa 4420 overheating
The laptop must be dismantled to access the motherboard, buy a can of compressed air attach straw. Now remove fan and the heatsink, blow out all open ports and fins on the heatsink and fan, next! remove thermal grease from the processor and heatsink with rubbing alcohol and a paper towel, now! apply fresh thermal grease to the processor and heatsink, "small thin layer evenly spread" now assemble, "solves most heat related issues"
Apr 19, 2012 | Acer Extensa 5630-6806 Notebook
My daughter called me this am from school. She said that her laptop seemed to be running hot, especially on the left side, and would shut down after about 15 minutes of use. I told her to run portable...
Joe- This does sound like thermal shut down. Unfortunately what I would bet has happened, is your daughter uses her computer on the bed often, which picks up lint. This lint ends up plugging the intake port of the computer. I believe the A105 has access to the fans on the bottom pannel which is really helpfull otherwise you have to take the laptop apart. you should get in there with a brush, a vaccume, compressed air and really clean out the fans, and the fins of the heatsink. I would also pull the heatsink from the processor clean both the processor and heatsink with Alcohol and apply artic silver thermal paste to it as per the instructions. Now reassemble. It should be all set.
As for the coolpad, if the fan is running, which I think it is, it will help. IT will not solve the problem, and the chip will continue to overheat and shut down but take longer to do so.
Jun 16, 2010 | Toshiba Satellite A105-S171 Notebook
Traffic Updates
Below is a link to the manual. Information concerning traffic updates is on page 16:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MV6521~6021~5021%20(EN).pdf
Aug 04, 2008 | Kenwood KDC-5021 CD Player
Kdc mp532u
Hello, I have kenwood kdc-mp535u with the word protect in the display….I do not have the code nor the control, that I can do?
May 10, 2008 | Kenwood KDC-MP535U CD Player
My AMD X 2 4000+ Windsor is overheatting
Hi, you shouldnt even switch on the PC if its running at that temperature, machine will be restarting and shutting down on you.
If you just bought it, you should take it back to the shop.
Otherwise you need to remove the old heatsink and fan and apply new thermal paste to the cpu and resit the heatsink, if its still running very hot over 50c you will probably find the cpu has been damaged.
Have a nice christmas
John
Nov 21, 2007 | AMD CPU Cooler Fan + Heatsink for up to...
Time
Hi Sdionne,
Use the following procedure to set you clock.
Nov 08, 2007 | Kenwood KDC-MP535U CD Player
Problem installing a Kenwood cd-receiver
will this be any help for you. http://12.4.198.133/S-BC7wTd7tyQP/App/Product/Item/Main.aspx?g=300&i=113MP535&tp=5684
regards
riz.
Nov 04, 2007 | Kenwood KDC-MP535U CD Player
Kenwood KDC-MP535U CD Player Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
