Zoek afstandsbediening voor Panasonic sa-ak 210
  • 236 Answers
SOURCE: Panasonic SA- AK 133 Music system sorround system not working
this is something a tech expert on electronics can handle. even replacing parts has to be attended by a pro-technician. something is wrong with your DSP processor or system components. it could be the switch only or it could be the processor.
Posted on Mar 31, 2008
tech48
  • 624 Answers
SOURCE: panasonic sa -ak 27
This is a common error for these Panasonic units. I work at an authorized Panasonic service center and have repaired many of these.
This error is caused by either 1 of these 2 problems, both of which will require service for replacement of parts.
1. The amplifier IC is bad and needs to be replaced.
2. There are a couple of smaller components in the amp circuit that need to be replaced. One is a zener diode and the other is a resistor.
The F61 error is caused by a bad amp circuit or power supply circuit. In most cases it is the amp circuit. More often than not, it is the zener diode and resistor that are bad. This would be preferable since the amplifier IC is very expensive and a total repair cost would be close to $200. The zener diode and resistor repair would be closer to about $100 depending on the rates of the service center.
I know this may not be the answer you were hoping to get, but it is the problem you have.
If you found this information helpful in making a decision on what to do with your stereo a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for offering free help to people like yourself.
If I can be of any further help just reply to the post and I will get back to you as soon as I am able.
Good luck with your stereo, I hope you found this information to be helpful.
Dave
Posted on Sep 05, 2008
rohntech
  • 422 Answers
SOURCE: How to Reset Panasonic SA-AK 44 musical center
1. to reset it try to unlpug it to ac outlet voltage.
2. also look for reset button (usually a small hole that needle will only suit to it) it usually hide but usually not all unit like your's have that.
3. there must be no mechanical jam inside the player, if there is then it need to be align.
Posted on Feb 04, 2011
dunnbiker
  • 8546 Answers
SOURCE: panasonic sa-ak 110 f61 error
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 18, 2011
  • 1099 Answers
SOURCE: ik zoek een handleiding voor
Je moet in staat zijn om de handleiding voor de macht boek G3 vinden op
http://support.apple.com/nl_NL/manuals/#powerbook Hoop dat dit helpt.
Posted on Apr 18, 2011
Panasonic sa ak 250
Panasonic remote controls can be obtained by calling 1-800-833-9626 or visit www.panasonic.com/parts. Parts Ordering
Apr 12, 2014 | Panasonic Audio Players & Recorders
Tip
Panasonic SA AK 67 Sterio system need spare
I have one panasonic SA AK 67 sterio system five disk changer
one plastic parts brocken inthe mechanisam area i wold like replace the mechanisam with lence what is the part number i could not find it where i can purchase new mechanisam. please help me
on Jun 30, 2008 | Panasonic SC-AK24 CD Shelf System
Nederland service Ik heb een hitachi projector (CPX 938) zonder afstandsbediening en zonder manual. Waarschijnlijk een verouderd model. Is het mogelijk nog een passende afstandsbediening en manual te
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 09, 2014 | Hitachi Office Equipment & Supplies
Ik heb de codes nodig voor een universele afstandbediening voor mijn samsung hitron black tv
Hallo
Driecijferige universele afstandsbediening codes voor Samsung tv zijn:
004 / 005 / 009 / 015 / 104 / 105 / 106 / 109 / 133 / 172
Viercijferige codes universele afstandsbediening voor Samsung TV zijn:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
1 * Houd de SETUP knop ingedrukt tot het rode lampje blijft branden, laat dan de SETUP knop.
2 * Druk op de gewenste knop Modus (TV, VCR, etc.). Het rode lampje knippert, dan blijft branden.
3 * Voer de 4-cijferige code uit de code tabellen. Let op: na een geldige code, het rode lampje uitgaat. Voor een ongeldige code, het rode lampje knippert.
4 * Met uw apparaat, druk op pijltje omhoog. Als het apparaat reageert, is er geen verdere programmering is vereist. Opmerking: Als sommige knoppen niet bedienen apparaat, een van de andere codes voor uw merk proberen. OK
Jul 16, 2011 | Televison & Video
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
Ik zoek een handleiding voor de powerbook G3
Apr 18, 2011 | Apple PowerBook G3 Mac Notebook
Panasonic model no sa ak 67 aux not work please makenic in bokaro
my set model SA-AK67
its cd mechanism motor is not working.supply ic coming from main pcb to cd loader ocb.please advice
Apr 12, 2011 | Panasonic SC-AK24 CD Shelf System
Ik zoek een gebruikershandleiding voor de gogear
Hello
Ek verstaan wat jy soek,calhoewel ek afrikaans is.
Jy sal die handleiding HIER kan aflaai.
Groete
Andrea
Jun 17, 2010 | Philips GoGear SA3020/37 MP3 Player
Zoek een nederlands talige handleiding voor BMW 1100 rt van 1998
Hallo , Ferdi_van_le spijt me u een Nederlands geschreven service manual niet vinden van de eerste en de beste tool die je ooit gekocht voor uw BMW , maar wanhoop niet voor slechts $ 0 unt u een ander downloaden . Voor meer informatie over uw probleem , unt u terecht op onderstaande websites. Veel succes en een mooie dag verder . 92 01 BMW R1100RT R1100RS Service Repair Manual CD
Hints and advice for BMW bike motorcycle owners K1 K75 K100 K1100 bulb...
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
http://www.ketchum.org/BMWmc/R1100.pdf
Mar 29, 2010 | 1998 BMW R 1100 RT (ABS)
Ik zoek een driver voor webcam funcam manhattan ik kan geen drivers vinden van model 460064
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 25, 2009 | IC Intracom Manhattan FUN! CAM Webcam
19 people viewed this question
 Grubhead
Grubhead
