Question about Cuisinart Food Mixers
Mixer works but paddles don't move - Cuisinart Food Mixers
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
The paddle will not dislodge from the mixer head for cleaning. It will not budge
Take a wooden spoon handle and tap up towards the mixer on the bottom of the paddle... then when it moves up about a quarter inch turn it counter clockwise to remove it...tapping at the top while trying to turn it may help...
Then before using again, place a small amount of Vaseline or other petroleum jelly on the shaft to lube it and make removal easier the next time...
heatman101
Jul 16, 2011 | KitchenAid Food Mixers
My 6 quart kitchenaid mixer paddle is rubbing the bottom of the bowl with the tip of the paddle and turning my product black
Find the screw in the picture as shown and screw it counter-clock-wise which will drop the bowl level down when it is in the raised position and the mixer paddle will not rub on the bowl.
http://www.fixya.com/uploads/images/07F1BE1.jpg
May 21, 2010 | KitchenAid RKG25H0XWH Mixer
Paddle beater won't push up and turn to release
When you are able to remove the paddle, feel the opposite side of the spindle. It should be smooth. The pin should not stick out the back at all. Carefully, tap it in until it is even with the spindle. That will fix you up, unless the pin itself is also damaged. If so, get a small file and remove any burrs from where the paddle mounts.
Feb 05, 2009 | KitchenAid K45SS Classic Stand Mixer
Motor is running but the paddle won't move.
If you bought this mixer less then 1 year ago, call KitchenAid at 800-541-6390. They have a "hassle-free replacement" warranty. They should ship you another mixer. I bought one recently and it died after 3 days of use. I called and they are sending me a new one. However, it is not comforting that these mixers fail so quickly. KithenAid use to be made a product to last many years. I assume the quality has declined. Good luck!
Dec 22, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
Beater doesn't turn
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 15, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Motor runs paddle does not move, oil from attachment port
Dec 14, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
