Question about Lexmark X1240 All-In-One InkJet Printer
Which black cartridge does this need?
I'm thinking of buying the Lexmark x1240 for home use, but I want to be sure I can get cartridges without paying a lot! I'm not sure if it uses #16, as I have trouble finding the info for this one. That makes me nervous, because I'm worried it will be hard to find cartridges. Also, can I refill them myself?
  • whitequeen96 Sep 25, 2007
    Thank you! That gives me all the information I could have asked for!
    Scholar:
  • 84 Answers
Yes you can refill the cartridges. Also Walgreen's refill cartridges now. $10. for black and $15. for colr cartridge refills. I've been using their refills and they work fine. It's less mess that doing it myself. And they use good quality ink... But you can refill them.They also carry universal refill kits at walgreen also. Also the cartridges are not hard to find you can order them at several places online. Google x1240 for sites. Also Staples sell the cartridges.
Posted on Sep 25, 2007
SOURCE:
Can not get the color to work in my lexmark x1240 printer to work? we tried to refill the old cartrage first but it leaked after a couple uses than we bought a new cartrage but it won't work.
Make sure that you are using genuine Lexmark cartridges and not refilled, re-manufactured or clone cartridges from the 3rd parties. Lexmark products work best with original supplies. If you are using genuine cartridges yet the problem persists, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
How do i clean the print nozzles on a lexmark printer x1240?
To clean the print cartridge nozzles using the Lexmark software on your computer:
  1. Open the Lexmark Solution Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
To manually clean the print cartridge nozzles:
  1. Remove the cartridges from the printer.
  2. Grab a moistened soft cloth and place it on a flat surface.
  3. Gently hold the nozzles against the cloth for about 3 seconds, and then wipe in the direction shown.
Reload the cartridges.
Nov 07, 2010 | Lexmark X1240 All-In-One InkJet Printer
Was given a Lexmark 1200 series X1240 all in one and cannot determine what type of ink cartridge to use.
The Lexmark X1240 printer uses #16 and #17 for Mono/Black, and #26 and #27 for Color. Hope this helps.
Jun 11, 2010 | Lexmark X1240 All-In-One InkJet Printer
I own a Lexmart x75 all in one printer. I have been using #16 ink cartridges. Can I use #17? and what is the difference?
You can use the Lexmark #17 if you would like to pay even more for your ink. The #16 cartridge is the high capacity version of the #17. A Lexmark 16 should have 12mL ($3.06/mL) of ink while the 17 should have only 7mL($3.42/mL). Also be aware that the ink used in these cartridges will suffer from water evaporation quite quickly. If you do not print a lot, the water will evaporate and leave behind an ink sludge that will not print. We do not recommend Lexmarks for those who only print occasionally.
Jun 09, 2010 | Lexmark Office Equipment & Supplies
My Lexmark 1240 printer has a new Bkack ink in it (Lexmark 16 cartridge) but still does not print black text or lines.
Check to make sure you have removed the plastic covering on the new ink cartridge contact.  Run a calibration/alignment test on your printer. (If you're not sure how to do this, Google "how to align cartridges on----- your modle printer).  Finally, you may want to do a "hard-reset" on the printer. Turn it off, unplug it for 30 seconds and try again. Good luck!
Jun 24, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark Ink Cartridge Issue
Ink cartridges do have a shelf life - usually about two years from manufacturing, but it's more likely that the nozzles have become dry or clogged as result of disuse. You may get things corrected by putting regular rubbing alcohol on a clean soft cloth and gently wiping the contact points between the printer and the cartridge. If that doesn't work, you'll probably have to replace the cartridges.
Feb 20, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lost installation disk for Lexmark X1240 all-in-one printer
i cannot find my disc for my 1300 lexmark printer. how can i down load it so that i may re- set up my printer?
Nov 05, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 cartridge Error
Try a pc reboot or try the owners manual for a reset sequence in the control panel on the printer itself Lexmark provides owners guides and a lot of useful info at thier web site here is the link if you are interested
http://www.lexmark.com/lexmark/site/home/0,6932,204816596_0_0_en,00.html
best luck
Aug 31, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
