Question about Apple iPod nano 3rd Generation
Ipod skips over many songs then freezes
If i want to move to the next song on playlist it skips over about 40 songs then freezes up
  • 342 Answers
Here is a helpful article from apple on learning how to reset your ipod.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If you still have issues after doing a reset you will need to restore the ipod using itunes and just in case you are unfamiliar with how to do that here is the instructions as well.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
I hope these steps resolve your issue good luck. :) CHEERS
Posted on Apr 23, 2009
How do i delete all my songs on my ipod?
Hi inthebag pik...
Try this easy way to delete your unwanted songs...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
Sep 17, 2011 | Apple iPod nano 5th Generation
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Jul 20, 2011 | Apple iPod touch
Hi I have a playlist on my itunes which when I download it onto my ipod, one of the songs is missed off. This song shows and plays on the playlist on itunes, and is on the main menu of my ipod, just not...
  1. Plug in your iPod to your computer and run iTunes.
  2. Sync your device.
  3. Re-check to make sure that song is under that specific playlist (if its not drag it onto the playlist)
  4. Make sure the box next to the song in iTunes is checked meaning it will sync with your iPod and your playlist.
  5. Apply the changes you have made to the playlist by re-syncing your iPod.
  6. If the box is checked and you sync your device the song should be listed under your playlist.
Mar 06, 2011 | Apple iPod 16GB nano Silver 4G...
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Dec 22, 2009 | Apple iPod touch
Songs skip
delete the track that skips and then put it back on again and let me no if it still happenes
Jul 18, 2008 | Apple iPod nano 3rd Generation
Skipping songs
i bought new songs on itunes and i got a notice when i was syncing my ipod that said "the file or directory is corrupted and unreadable" and now my ipod skips over the songs i just bought.
May 10, 2008 | Apple iPod MP3 Player
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
Apr 13, 2008 | Audio Players & Recorders
How to download
If you are asking how to add songs to you iPod
(assuming you want to use iTunes)
Sync your iPod with iTunes
  1. Connect your iPod to your computer.
  2. When the iPod icon appears in the iTunes window (below Devices), select it.
  3. If the Summary pane isn't showing, click the Summary tab.
  4. To automatically sync your iPod:
    1. Make sure that "Manually manage music" is not selected.
    2. Click the Music tab and do one of the following:
    3. To automatically update your iPod with all the songs and playlists in your library, select "Sync music" and then select "All songs and playlists." iTunes loads the songs and playlists in your iTunes library onto your iPod, and deletes songs from your iPod that aren't in your library.
    4. To automatically update your iPod with only certain playlists, select "Sync music" and "Selected playlists," and then select the playlists you want synchronized.
  5. To manually sync your iPod:
    1. Make sure that "Manually manage music" is selected.
    2. Click Music (below Library, on the left side of the iTunes window) and then drag songs and playlists to your iPod.
Feb 23, 2008 | Apple iPod nano
Phantom Songs on my Sansa e250
Use Windows Media Player to delete, or double-check the format of those songs
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
Apple iPod nano 3rd Generation Logo
125 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
