Question about Honda Pressure Washer PSI 3000
Changing engine oil on a gx390 engine for pressure washer excel
Can't find the place to change the oil
  • fredericko May 21, 2009
    What kind of oil do I use?
    President:
  • 710 Answers
On the very bottom of the motor is a square plug to drain the oil. The machine must be elevated to allow the oil to flow into a drain pan. If you don't see a square plug then look for a small 1/4 inch tube coming from the bottom of the crankcase with a hex cap on the end of it. If you cannot find either of these, then you must turn the pressure washer on its side and drain it through the same plug you fill from.
Posted on Apr 24, 2009
What oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
A gas power waher 3500 psi ,with a honda gx390..Start proper but after 15 minutes turn off by it self.How i solve this problem??
hi there aldao62367
if the oil level is at correct level , check that the tank breather in the fuel cap is clear
then change the oil it may be thinning out , and low oil sensor float is not floating and makes the unit think its got a low oil problem - shuts down, also check for a tight valve ?
off the top of head valve clearance for inlet 0.005 thou and ex 0.007 thou
change oil to a 20w/50 or 10w/ 40 oil
should hold about 1.0 litre
cheers pauly46
Jun 02, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
How much oil do I put in my Honda GX390 13hp Pressure Washer. Theres no lines on the Dipstick
you fill the oil up to the dipstick hole,just so it doesn't over flow out.
Nov 13, 2010 | Honda Garden
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
May 24, 2010 | Karcher G 2600 VH Gas Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Honda GX390 stalling in go cart
I believe its the the oil sensor. The engines are equipped with a low oil sensor and when you go around turns, accelerate, decelerate, the oil will flow from side to side and throw the sensor off, causing the engine to shut off. Remember, this is because the engine is from a pressure washer and pressure washers arent meant to be driven LOL.
Mar 14, 2009 | Honda Garden
Honda Pressure Washer PSI 3000 Logo
2,227 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
