Question about Kenwood Double DIN Navigation DVD Receiver - DNX570HD
Is there any way to dim the display on the Kenwood DNX570HD? It dims slightly when the lights are turned on but for night time operation it is still too bright. I have looked through the manual and online but cannot seem to find anything regarding this issue
IPOD cable doesnt work on my DNX570HD
I have the same problem, did you find a solution?
Jan 10, 2014 | Kenwood DNX570HD
Display is very dim in the daytime.impossible to see anything
Do you have the display lighting turned down, there is a control for the brightness.
Aug 17, 2012 | Cars & Trucks
I have a 1997 Ford escort. The drivers side electric window has ceased working. Passenger side ok. What is the possible solution please
The window regulator has failed or the wiring to it or the switch is defective for the window. If the switch is ok you should see the dome light dim slightly when the window switch is operated with the door open to keep the light on, better to do this at night. If the interior lights dims a tiny bit then the motor is defective and you will need to replace the window regulator.
Jun 28, 2012 | Ford Cars & Trucks
Power window troubleshooting
A quick way to tell what is causing a window not to work if you hear nothing when the control switch is operated is to watch the interior lights when you operate the window in question, if you move the switch to up or down and the interior lights very slightly dim (best done in the shade or at night) you have a defective window lift motor, if you see no dimming the switch is suspect or it has no power or a poor ground. This is not fool proof but it works most of the time.
Feb 09, 2012 | 2002 Honda Civic
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Instrument panel lights do not come on.
Soldering the new bulbs in may have done something to the LH DIMMER MODULE ! The 10amp INT LPS fuse located in the I/P fuse box is good ? Is the dimmer switch at full bright ?
When the park lamps are on, battery positive voltage (B+) is supplied through the instrument panel (IP) fuse block INT LPS fuse via CKT 32 (YEL) to the dimming switch. The dimming switch supplies a variably controlled voltage to the dimmer module(s). The potentiometer in the panel dimming control cannot provide enough current in order to operate the panel lamps. The dimmer module(s) amplifies the current, supplying the variable voltage to the panel lights. As the amount of the current increases, the lamps become brighter. As the amount of the current decreases, the lamps become dimmer.
Buick
There is only 1 dimmer module that supplies current to the panel lights. The left dimmer module supplies current via CKT 8 (GRY) to the following components:
• The headlamp switch
• The door switch flood lamps
• The heater and A/C control
• The door handle flood lamps
• The passenger temperature control
• The ashtray lamp
• The shift select switch lamp
• The instrument cluster
• The steering wheel controls
• The reset switch
• The trip odometer
• The radio
Parade Dimming
The parade dimming feature prevents the dimming of the VF displays when daylight is sensed by the lamp control module (LCM) and the park lamps are turned on manually. If the LCM senses night time conditions and the park lamps are on, the LCM allows the VF displays to be dimmed.
All of the modules with the VF displays receive the dimming level from an input on CKT 8 (GRY) or CKT 1244 (BRN). When the LCM determines that the above conditions are met, the LCM sends a signal to the instrument cluster and the radio via CKT 390 (YEL). For Buick, the radio then relays this information to the heater and A/C programmer and passenger temperature control via CKT 724 (PPL/WHT). The modules with the VF displays then adjust the dimming level of their VF displays to match the level of the incandescent lights.
LH Dimmer Module
Under the left side of the IP, on the left side of the steering column brace
May 25, 2017 | 1998 Buick Riviera
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Connect to the side light live. So when you turn the lights on it dims the display.
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Dim Mode
Make sure the orange wire with white stripe is connected to your dash illumination/parking lamp circuit. There should be a tag on it that says 'ILLUM' (unless the installer clipped it). That should dim the display whenever your lights are on.
If that doesn't do it enough I think your going to have to dial down the brighness - and that will do it for all functions.
Feb 13, 2009 | Kenwood DNX7100 Car Video Player
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Driver power window will not roll back up
A quick way to check if the motor or switch is the problem is to perform this test, at night operate the window switch with the door open, if the dome light dims slightly most likely the window motor is defective or the regulator is jammed, if no dim is observed then the switch is most likely the problem, very quick and easy to do.
Nov 03, 2008 | 2001 Nissan Altima
Kenwood Double DIN Navigation DVD Receiver - DNX570HD Logo
247 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
