Question about Dryers
Kenmore elite 8908
Dryer turns on but does not start. Can push buttons to change programs, and the timer starts counting down, but the dry does not start spinning. I think there is a sensor problem?
jsrock516
  • 5911 Answers
SOURCE: kenmore elite he3 electric dryer
If you get a series of four rapid beeps when you push START in an attempt to start your dryer, your door switch (interlock) is defective.  I have experienced this problem before and it is a fairly simple problem to fix.  The easiest way to tell is to open the dryer door and push the door interlock in by hand.  Hold it in while pushing the START button.  If the dryer starts, then all you have is a simple problem of the door not closing properly.  If the dryer still does not start, however, replace the dryer door interlock.  The interlock should also make a definite "click" while pushing it in.  If it does not, the switch is worn out.  Some dryers have an upper and lower door interlock.  If yours is equipped with two interlocks, make sure they are both functioning and that the door is latched properly.  I have experienced problems where dryers doors with two interlocks would close at the top, but not at the bottom.  The dryer would not start as a result.  If you can provide me with your model number I can get a part number and price for you.  I can also tell you where you can get the part and provide instructions on how to replace it.  Let me know.  I hope this helps you.
Posted on Oct 31, 2007
Master_Tech
  • 770 Answers
SOURCE: Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Posted on Jan 21, 2008
AlmostBob
  • 550 Answers
SOURCE: Push to Start switch does not Start Kenmore Elite Dryer Mod # 11065944401
A likely cause is failure of the relay.
the start switch provides a current to energise a relay,
the relay latches open (draws energize current from switched circuit) until current path is broken by the timer or door switches.
if the wires have come off the relay(happens) or the coil of the relay has failed, there will be no start.
With plug pulled
trace the wires from the start switch, to the first device, looks like this 8fc4980.jpgmay be opaque. if any of the wires have come off refit them and retry start.
relay diagram looks like this 5a14628.gif test with meter for conduct between terminals labelled 85 86 (or Coil in other labelling standard),
or take to appliance parts store, can test and provide replacement on site.
Appliance part store will likely provide part labelled whirlpool, not a problem all the small parts are interchangeable
NOTE dryer relay may have up to 8 terminals,
2 for coil
3 (open close common) for each phase
Posted on Oct 30, 2008
richroth
  • 9472 Answers
SOURCE: my kenmore elite dryer will not start up,all the
There are some things about the "Check Lint Screen" light you should know. It's a reminder light and doesn't actually check anything. When you select a cycle it should come on and stay on until the Start button is pressed, the door is open or after 5 minutes.
If the Control Lock is not turned on then you may have to replace the console/interface to resolve this problem.
A hard reset is used to describe a reboot process. With the dryer stopped and the control turned off (if possible), unplug the dryer to completely disconnect electrical power. If it is difficult to reach the dryer outlet plug, you can shut off the breaker for the dryer to completely disconnect electrical power. Leave the electrical power completely disconnected for 5 minutes. This will sometimes reset a control board that is stuck due to a power surge or glitch encountered through the electrical lines. Plug the dryer back in to see if the control will operate properly.
If the control does not reset and work normally after the hard reset, then you could have a stuck "touch up" button on the control. The image below describes a diagnostic test mode that can be entered to check the buttons on the control. If you are able to enter this mode, you can check to see if the "touch up" button is stuck. You may not be able to enter this mode with a stuck button, bad user interface control board or a failed machine control board. If the dryer will not go into this diagnostic test and the console will not respond to other cycle selections, then I recommend calling a service technician to diagnose and repair the dryer. It is likely that the user interface control board will need to be replaced.
Test Mode Sheet
Posted on Dec 11, 2010
heatman101
  • 43501 Answers
SOURCE: i have a kenmore elite dryer that will not start -
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Dec 27, 2010
Dryer turns on, but with every cycle option, the dry and cooling lights are both illuminated, the former blinking. When I try to start the cycle, I hear a short hum, then nothing. The barrel doesn't turn,...
Possible that the motor capacitor is faulty and not lettingg the start up. Opne and get access and change the capacitor . If you are hearring then hum then when you touch the motor it should be quite warm which confirms the failure off the capaccitor or the winding of the motor.
The timerr runs accordingly not knowing if the motor rotates.
Hope this helps.
Aug 26, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
The timer mechanism is faulty. replace it asap.
Jul 23, 2009 | Roper RES7646KQ Electric Dryer
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
May 12, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
