Question about KitchenAid 30 in. KGCS105GSS Gas Cooktop
My fan works but it does not pull the smoke or heat toward it. Is there a blockage? Is there a filter that needs changing? Help!
    Problem Solver:
  • 11 Answers
The filter is always good to check first. If not chances are its a flow problem a shop vac works wonders.
Posted on Apr 24, 2009
Jenn-air CCE3401 Radiant cooktop one burner takes a long time to heat. has since purchase.Advise
Turn off range circuit breaker.
Remove burner and measure the connections across it. See how many Ohms you get.
Do the same to an identical sized burner which works well and measure its resistance. If the numbers differ considerably the burner needs replacement.
You had mentioned you own a 'radiant' cook top which implies a glass type top, in that situation you may need to pull the oven out to get to the rear connections.
If you decide to continue on this project you may have to pull out the lowest drawer, this will expose the safety bracket which prevents the complete oven from falling over and hurting anyone who may lean inadvertently on the oven door and cause it to tilt forwards.
When the oven is slid to the front the first 5-6 inches keep it from tilting. This is mentioned now because once the oven is removed and is pushed back towards the wall afterwards, the bracket may not align properly and you may be puzzled as to why you can't move it back. In addition there may be a crowfoot connection (voltage) which needs to be disconnected if it's not long enough for access.
Most ovens have a folded piece of paper in the rear which shows the schematic diagram. This is sometimes in a clear bag which sticks permanently to the oven. It's meant for the service technician.
When the oven is removed and looked at from the rear a plate just below the burners may have to be unscrewed. This will show the various electrical connections. See the schematic for help...and
before you undertake such a task, I'd suggest you would look on You-Tube on checking burners, etc. It may stop you in your tracks and get a serviceman to help you.
There is a company called Appliance Zone which I used for my microwave front panel replacement. They carry everything for large appliances.
They are good for parts and general assistance.
If you have and use a VOM at home you seem to realize on how to apply your talents, otherwise I would consider getting professional help.
Feb 02, 2015 | Jenn-Air Cooktops
How do I remove based grill
You should be able to get your fingers behind it, either on both ends or underneath. You MAY POSSIBLY need to open the freezer door a little and hook your fingers behind the top of the grille.
Jul 31, 2014 | KitchenAid KFXS25RYMS
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Exhaust turns on automatically in burner mode
Hello
I have the one with the 4 burners and the grill, and when the grill in on the fan has to come on, and it does automaticly, but once you finish with the grill you have to change it back to stove mode by putting the 2 burners back or the fan will allways go on when you turn the switch. It is a safety regulation for the fan to be on with the grill to avoid the fumes......I know I hate that too.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 19, 2008 | GE 30 in. Profile JGP979 Gas Cooktop
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Exhaust fan not starting
Hi
I have all the diagrams for that model and will gladly send them to you all for free via email. Remenber that the fan will always get gresse and have to be clean, also keep the filter clean.
Let me know were to send the diagrams...Glad to Help!!
Eddie Rentas
Tupper Lake NY
Apr 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 8130 installation problem
Rotate the blower to the proper angle
needed for your installation. The blower
can be swiveled 90°. To rotate the blower:
a) Remove the filter from the blower housing
b) Loosen, but do not remove, the nuts
around blower inlet.
c) Rotate the blower housing for the
proper angle.
d) Retighten the four nuts and install the
filter.
try this its general for this type of cooktop
Mar 30, 2008 | Cooktops
Downdraft fan not pulling test card down
whats you model number as does it sound like fan is running and what do you mean by not pulling test card down did you just install it or had it for awhile i will try to help
Jan 02, 2008 | Jenn-Air JED8430 Electric Cooktop
KitchenAid 30 in. KGCS105GSS Gas Cooktop Logo
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
freddyfox
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
