Super general error E1
I have a f4 e1 code on my washer
Generally e1 error is pressure sensor error change pressure switch or wayer
Aug 08, 2016 | Washing Machines
What is error code E1 mean
i'm sure you already found out that you have or had a bad thermister located on top of the blower wheel housing,just answering this in case somebody else has this problem.e1 error code is bad thermister
Sep 30, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Super general SGW7100 E1
my washing machine super general sgw7100 has error E-62! how i solve this problem?
Feb 19, 2013 | General Electric WHDSR209DWW Top Load...
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
E1 or E2 Thermistor Failure
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool super capacity 465 electric range. i get error codes that beep and flash e1 and f1?
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool oven timed bake feature dosn't work.
Oct 25, 2009 | Whirlpool RBS275PD Electric Single Oven
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
