Question about Fisher PC-32S80 TV
No picture I turn the TV on, and you hear a click. The tube will flash for a second, and then click right back off. This just started on 9/20/2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As your tube flash for a second & then click right back it means you are getting power for that particular time means there might be some cold solder in power supply. if it is ok then check for horizontal section for cold solder or some print loose.
Posted on Oct 01, 2007
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Sony Trinitron screen flashing
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
Dan
Dec 17, 2009 | Sony Televison & Video
Tv will not turn on
If it is a convergence issue, you can unplug the cable that connects the two boards all the way toward the front. If the tv comes on with a VERY bad picture(no convergence) then your problem is in the convergence ckt. If not, you could have problem with your small signal board. Also, the "yellow" problem you are having is that the cooling fluid in your blue tube is getting cloudy and needs to be changed.
Jul 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture flashes off but still have sound
You may want to change the lamp. It may be on the edge of failing totally.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony XBR 40" tube 2003 purchased
Soouds like the High Voltage board. It can be repaired. I did mine for liek $16. Ordered to chips soldered them in and viola, TV.
Scott
scott@vzandt.net
Jun 02, 2008 | Sony KV-36XBR400 36" TV
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
71 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
Jose Ma DM.
Jose Ma DM.
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
