Question about Craftsman 2700 Max Psi Pressure Washer 23 Max Gpm
My craftsmen 2700 pressure washer does not pump water out when garden hose is hooked up and putting out water into the unit
Why the pump on troy bilt pressure washere keeps going bad?
you need to use briggs and stratton pump saver over winter to keep water from freezing and keep the pump lubricated. also never start it if the hose is not already turned on and supplying water to it.
Aug 02, 2017 | Troy Garden
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
AT FIRST WITH JUST THE WATER ON (PUMP OFF) I SQUEEZE THE WAND AND WATER COMES OUT ABOUT 3 FT. THEN WHEN I START THE PUMP AND SQUEZE THE WAND ONE STRONG SQUIRT COMES OUT THEN GOES BACK TO ABOUT 4 FT. NOT...
Hi, W/D here.
Leave the water on, and hold the trigger down for about 5 minutes to get all of the air out of the system. Letting off of the trigger occasionally and then opening it up will help displace any air in the chambers. While still holding the trigger down, start the washer. Should put up your desired pressure.
Best regards, --W/D--
Feb 14, 2011 | Comet Axd3020g Pressure Washer Pump 27 Gpm...
The garden hose was used to siphon water from a dirty pool. The hose was connected to the pressure washer without cleaning out the hose and turned on. After a few minutes he couldn't get pressure from the...
Hello, check the hose connection on the pump. There is generally a screen there to prevent dirt from entering the pump. Clean off this screen and all should be well.
joe
Jan 27, 2011 | Karcher K3.68MR Electric Pressure Washer
My Powercraft 9686 pressure washer has always been stored in my garden shed. It is 4 years old and when I used it last September the power washer had lost considerable pressure, as it was leaking water....
put some silicon spray in inlet/outlet then reattach hoses then run it will proform after a while do this everytime you store it pryer to sroring away...........
Jan 17, 2011 | Craftsman 2700 PSI Briggs Stratton...
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
KOHLER HYDRO 13 When pressure washer engine is
first sheck the inlet screen where the garden hose attaches,if there is water flow then see if it has a manual pressure regulator, this will be a knurreled knob somewhere on the intake manifold of the pump, ifyou have one, turn it clockwise and see if there is a difference. If still no luck, disconnect the high pressure hose from the pump, start it and see if warer flows at that point, Your gun may be clogged or your hose may be delaminating on the inside and need to be replaced. If all this fails I suggest you bring it to an expert. These pumps can require special tools and expertise to repair internally
Nov 08, 2009 | Karcher 2500 PSI Pressure Washer
When water is hooked up and turned on I have water coming out the
On some pressure washers there is no bypass. If this is supposed to bypass, then the pressure bypass is faulty.
Jun 16, 2009 | 2004 Sym Husky 125
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Craftsman 2700 Max Psi Pressure Washer 23 Max Gpm Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
