Question about Dell F3534 Touchpad
Touchpad and all 4 buttons stopped working
I have done a one day system restore (back to when it was working).
I have gone to Dell, downloaded the touchpad driver, and loaded it.
Rebooted 3 times.
Still no touchpad or buttons.
Yes, the USB mouse dose work.
4 Suggested Answers
SOURCE: touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Posted on Sep 05, 2008
SOURCE: Dell Inspiron 8100 touchpad
Contact Dell Support, and they walked me through the process to fix the touch pad problem. They had me download/reload the software for the touch pad and it works.
Posted on Oct 03, 2008
cpenzes
  • 1102 Answers
SOURCE: Touchpad dell vostro 1000
your touchpad may just need cleaned
or have you shut it off or disabled check control panel and mouse then device settings if you see enable then click and apply
don't forget to rate me
thankx
Posted on Feb 02, 2009
Hello, im having problems with the touchpad of Dell Latitude D410. I cant tap it to click, and the buttons not working, luckily i have a glide point. I hope it wont stop working.b
You can tried to up date the driver. If you go to dell.com you can find the driver and download. If not you need to replace the touchpad.
Thanks,
Nov 21, 2010 | Dell Latitude D410 Notebook
My Dell Inspiron N5010 Touchpad Scrolling doesn't work please any one tell me the solution?
double click the pad nd then move up or down as u like.....
do let me know if it works for u...... it works for me
Nov 02, 2010 | Dell F3534 Touchpad
My mousepad stopped working
First try reinstalling the driver for the Touchpad. The driver for the Touchpad can be found here: http://support.dell.com/support/download
Once this has been installed there should be icon in the lower right hand of the Taskbar that will allow you to adjust settings. If this does not correct the problem try using an external mouse to see if the problem follows. If the issue does not follow the Touchpad might need to be replaced.
If the system is out of warranty a replacement Palm Rest can be ordered directly from Dell by calling 1-800-357-3355. Instructions for replacing the Palm Rest can be viewed here: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/palmrest.htm#wp1045812 Another thing to try before ordering a replacement Palm Rest is to try reseating the" touch pad connector" to see if it corrects the problem.
If the issue does follow the mouse that is plugged in this could be an issue with the OS. An earlier restore point or a system restore could fix the problem (please be aware that a complete system restore will remove the data on the system). If this does not fix the problem then the system board might need to be replaced.
Jun 01, 2010 | Dell Inspiron 1501 Notebook
I have a dell insipron 1545, the mouse keys below the touchpad have stopped working in normal mode but will work in safe mode. I have Windows Vista
It seems to be a conflict with Touchpad drivers. For once, you can try a System Restore to resolve this issue. Else, you need to install the Dell touchpad drivers and application from the Dell support website to resolve this. You can download the drivers from the link after you select the correct Operating system version: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=. Save the file on desktop and right click on it, to Run as Administrator. Install the drivers and reboot your system. Now your Touchpad should work normally even in safemode.
Oct 23, 2009 | Dell F3534 Touchpad
Have a Latitude D410 running Windows XP Professional. This morning, the touchpad stopped working after coming out of hibernation. If I powerdown and reboot with media base, both the attached mouse and...
try to do system restore it might one of the windows update causes the problem, if fails check system bios compare it from the dell support site if its out dated download bios then flash.
Oct 12, 2009 | Dell Latitude D410 Notebook
Dead dell touchpad x(
Have you tried System Restore? If not familiar... Start Button ---> Help ---> System Restore ---> "Restore my computer to an earlier date" --> choose an appropriate date, maybe a few days earlier than the problem.
Re-boot and see if works! If you are ceratin that the problem arose simply from hibernating, then restoring should do the trick!
Hope this helps!
-- RT
PS - Don't forget to vote!
Sep 07, 2009 | Dell Latitude D610 Notebook
Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Sony VAIO VGN-CR420E/T Laptop
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad no longer working
go to control panel and click on devices. click mice and see if it has been disabled.
Feb 28, 2009 | Dell Precision M60 Notebook
Dell Inspiron E1405 touchpad does not work
regarding touchpad log on to this link and download touchpad drivers
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
make sure you choose the operating system correct and install Input Device Drivers
you will find 3 options you have to download the third one
Dell - Driver Applies to: hiernest.gif Touchpad / Pointing Stick
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
if you are in United states call 1-800-624-9896
Apr 15, 2008 | Dell Inspiron E1405 Notebook
Computers & Internet Logo
864 people viewed this question
Alun Cox
