Question about Dryers
Dryer won't start.
My dryer won't start. Lately I had to carefully close the door and push on the corners, then it would start. Now, it won't start at all. Is there a sensor that knows when the door is closed and not closed?
  • mollygabe Apr 24, 2009
    The switch/stryker does not look broken or bent.
  • commissiondr May 11, 2010
    There is a pin switch receiver, usually plastic or nylon on the body of the dryer. Stryker is on the door. Either may be broken. See if either looks bent, broke, etc.
  • 113 Answers
There should be a push in switch that the door pushes against
Posted on Apr 24, 2009
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Jul 01, 2014 | Kenmore 62602 Electric Dryer
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 21, 2014 | Kenmore 659 Electric Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
Won't start
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Dryer won't come on
check the door switch in the corner of the door
see if it broke off
Apr 23, 2009 | Kenmore Dryers
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Dec 31, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
