Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Install deck belt on Z510A John deere - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Can i have a belt diagram for a john deere stx38 please , thanks pete
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Click on the above link then do a "model search"
click on which model (either yellow deck or black deck)
alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or you can try the link below.You will need to sign up(free I think)
http://www.pdfph.com/pdf/john-deere-1999-stx38-hydro-deck-belt-diagram/
The link below has a picture of the belts on a yellow deck.
http://www.askmehelpdesk.com/tools-power-equipment/installing-belt-jd-stx38-hydro-385391.html
May 16, 2011 | John Deere Garden
I need a diagram of the belt on a black deck John Deere STX38 can you assist Thanks Deb
Follow this link: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt then do a "model search"
click on which model (either yellow deck or black deck) alphabetically pick which belt,
Or this website:
OutdoorPowerInfo.com © 2011
Or just 'google':
Installation of John Deere STX38 and STX46 Hydro Drive Belt (Black Deck)
Good luck.
Mar 05, 2011 | John Deere Garden
V-belt route installed on 48" deck of John Deere LA130
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
