Question about Canon IR 5000 Copier FG6-7904 4941 Main Controller
I have a problem in canon ir6000 giving error code e225-0000
Cogz
  • 1326 Answers
SOURCE: iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Posted on Nov 07, 2008
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
randula7
  • 78 Answers
SOURCE: error code e000020 in ir6000
E020
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Posted on Oct 25, 2009
Cogz
  • 1326 Answers
SOURCE: canon IR6000 shows error code E000061-0001
A E00061-0001 deals with the drum charge is missing. I would look to see if the primary charge unit is installed correctly, if so I would pull the unit out and make sure none of the corona wires are broken.. could be one of the post wires or the grid is broken. You may also, have a end block that is arching out. If you are not a service tech, you will need to call one to repair the code. It can't be cleared till it is fixed... Good Luck
Posted on Nov 02, 2009
Canon ir6000 error code is morning E0061
Dear
The mode selection has problem, pl. check the laser unit shutter, LSU and DC controller PCB.
The above are the measure if the error code has no sub-error.
Thanks.
Jan 19, 2015 | Canon imageRUNNER 6000 Copier
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Canon ir6000 giving error e225
Error code E225 on Canon
1. CIS lamp is bad.
SOLUTIONS:
1. Turn the power OFF and then back ON.
2. Replace the CIS unit.
Oct 12, 2013 | Canon iR5000-6000-L1 PS Ver 1.0
Canon IR6000 shows error code E000061-0002
this is problem Error E000061-00021 how to solve plz send Answer
Dec 14, 2012 | Canon imageRUNNER 5570 Copier
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail ahlalrasyid@yahoo.com. ty
Feb 16, 2010 | Canon Office Equipment & Supplies
Vinod canon ir6000 error e00061-00001 i cant
hai,one ir6000machine in oneand most problem eo61-01 please solution in this problem thnk you.
Dec 08, 2009 | Canon imageRUNNER 8500 Copier
Canon IR 5000 Copier FG6-7904 4941 Main Controller Logo
49 people viewed this question
old marine
old marine
