Question about Philips 60P8341 60" Rear Projection Television
MY TV DIED=(
HI, I HAVE A PHILIPS BIG SCREEN, #60P8341A. I TRIED TO TURN THE CABLE BOX OFF THEN A BIG PINK BOX POPPED UP IN THE CENTER OF THE SCREEN. I COULD STILL SEE THE CABLE ON AROUND THE OUT SIDE OF THE PINK BOX BUT I COULDN'T TURN THE TV OFF WITH THE REMOTE OR THE TV'S POWER BUTTON, SO I UNPLUGED IT, AND NOW THE TV CAN'T GO BACK ON AND THERE IS NO RED POWER LIGHT ON IN THE FRONT.
  • lndppr Apr 24, 2009
    I have the same problem. I turned the tv off and now it wont come back on, what can I do?
  • Philips Master
  • 3,866 Answers
Your controller board went out inside the TV and needs repair. I hope this information helps you out.
Posted on Apr 23, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    can you adjust your rating a notch up please that is if i did not help you out thanks.
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Green color has taken over tv
OK IF THE COLOR GREEN HAS "TAKEN OVER YOUR TV" AND YOU USE A CABLE BOX, ITS PROBABLY THE CABLE BOX. I HAD THE SAME PROBLEM. YOU JUST NEED TO EITHER HIRE SOMEONE TO COME TAKE A LOOK AT THE TV AND/OR CABLE BOX, OR BUY A NEW CABLE BOX AND/OR TV! SIMPLE,HUH?
May 31, 2009 | Philips 50P8341 50" Rear Projection...
Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
May 06, 2009 | Sony Televison & Video
Phillips 55'' rear projection tv model #55pp970104
That is a convergence problem, it may be because of a faulty defective IC.
Feb 09, 2009 | Philips Televison & Video
Big black box across the screen towards the bottom.
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Dec 13, 2008 | Toshiba CF36G40 36" TV
Black box in center of screen
The Panasonic call center helped us with this one. Our Closed Captioning had been turned on through the TV settings. This made us have a black box with everything besides our cable. Turning off CC on our TV Main Menu solved the problem for us.
Jul 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips LCD picture too big
depending on your cable syayem there might be an easy solition right on your remote or as a setting in your box - they have zoom settings also that seem to superseed all settings your TV has
Apr 22, 2008 | Philips 42PFL5332D 42 in. LCD Television
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 60P8341 60" Rear Projection Television Logo
176 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
