Question about Dishwashers
I have a new Kitchen Aid dishwasher model KUDE70FXPA3 and trying to use it for the first time. The controls are in the locked mode and I can't get it to unlock. What do I press to unlock the Dishwasher?
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 3 Answers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
iwillfixforu
  • 619 Answers
SOURCE: I cannot unlock the controls on the panel
Try turning the circuit breaker off for 30 minutes. Then turn back on and see. If it keeps locking you may need new control console. Hope this helps.
Posted on Feb 23, 2010
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
I have kitchen aid dishwasher. #KUDE60FXSSA. I trying to start a cycle an the control lock turns on. The cycle won't start. How do I bypass the control lock?
The final character in the model number should be a number. Most Kitchen Aid manuals are available here: http://www.kitchenaid.com/customer-service/manuals/ . From the manual for the KUDEFXSS4, there are only two possible buttons that toggle the Control Lock. On some models, there is a Control Lock button with "Hold for 3 seconds" in a small font below the key. On the others, the 4 Hour Delay button has this feature. There is a label below the key, "Control Lock 3 seconds". Again this is in a small font. See page 9 of the user manual to see the pictures and descriptions of the buttons. For the KUDEFXSS4, the direct link is http://www.kitchenaid.com/digitalassets/MLPDF/User%20Instructions%20-%20W10596243.pdf .
Press and hold the appropriate key pad button for 4 seconds to toggle the control lock off. The dishwasher will remember the Control Lock state until it is toggled on or off. The Control Lock is useful when you clean the dishwasher.
I hope this helps.
Feb 11, 2018 | Dishwashers
My double drawer kitchen aid dishwasher is stuck on rinse mode
I tried this once an it worked. Tech came from Sears an asked where fuse box was. He tripped the breaker for dishwasher. Flipped it back on after 10 seconds. Came to the dishwasher an it was like new again. He said sometimes they need a reset. If that did not work he had to replace the panel. Hope it works for you.
Jan 28, 2015 | KitchenAid Kitchen Aid Architect II 24 In....
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
I have a kitchen aid dishwasher model # KUDM01TJWHO The clean light has a 7 code. Your link to diagnostic mode/reset didn't work for this model. The tech sheet isn't behind the kick plate nor door panel....
you need to see if your getting power from the control all the way to the heating element something in the heating system is not working. some times the element burnes out and takes out the other stuff with it, so check for continuity at the element and thermostats befor replacing the control if all are bad it cost as mutch as a new washer or allmost
Dec 08, 2009 | KitchenAid Dishwashers
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Hi bluepanther,
I'm Harvey the Master Plumber.
Your problem is: You have a Kitchen Aid Dishwasher that has a light on saying CONTROL LOCK,of which when on you can't do any wash cycles.You tried doing canel out,but no help.What can you do to get off so can use unit?? Is there a reset button underneath that will reset unit.you are very mechanical and can pull unit apart if needed....Thanks Scott
Should not be nessessary. The lock is for keeping playfull little hands from getting into trouble. You must have inadvertently activated it. Try pressing and holding the "heated dry" button. This should deactivate the lock after about six seconds. This same procedure will reactivate it should you feel the need.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | KitchenAid Dishwashers
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
