Question about Braun 360° Complete 8985 Electric Shaver
Trimmer will not stay engaged - Braun 360° Complete 8985 Electric Shaver
Pull cord on gas trimmer recoils but doesn't engage motor
pull the recoil section of the motor and there will be a small plastic tag that engages inside the pulley
they have a habit of breaking away cost around $6.00 aud and are the same for all trimmer motors.
Jun 30, 2015 | Garden
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Stihl FS100 trimmer will not stay running unless throttle trigger is continuously engaged?
Idle might need adjustment. Clutch spring might need replacement
Aug 13, 2013 | Stihl FS100
Grass trimmer head keeps turning without power applied to throttle
On an Echo, this means that the clutch is staying engaged to the walls of the clutch drum. Either the clutch drum is loose and the clutch pads are catching it as it turns, or the idle on the engine is set too high and the centrifugal clutch is just opening enough to catch the drum and spin it. Check the clutch housing and your idle speed.
Jun 12, 2011 | Echo Garden
Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Nov 15, 2009 | Brother PC8500D
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Braun 360° Complete 8985 Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
