Question about Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1
Oil capicity - Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1
Coleman presidential furnace
bad fan control switch or bad fan motor
Nov 28, 2017 | Coleman Heating & Cooling
What petrol mix does it use, and what type of oil
Depends on what type of saw it is some very new ones use 50:1 oil fuel mixture older ones use 25:1 mix and the larger the bore or engine capicity you should probably use a little more oil to protect it, Mose saws will give the oil fuel ratio on the gas cap or in the owners manual
Brad
Aug 01, 2011 | Garden
Rear end capicity
It take's a total of 1.64 qts.
75w-140 Synthetic gear oil.
Jun 30, 2010 | 2005 Pontiac GTO
Power went out today and the TV is not turning on now
Most likely when the power came back on, there was a surge that damaged the power supply board in your TV. If your TV is completely dead with no blinking or standby lights, then the power supply is bad.
The power supply is the first board that the plug from the wall is going into.
You can check this by taking the back cover off and check for capicators that have gone bad. These will be capicators that look bubbly on the tops that are budging out. If you see any and know how to solder, replace these capicators with the correct voltage and Farad readings that are usually listed on the capicators themselves. Make sure to mark which side the white stripe on the side of the capacitor is as the orientation is very important.
Replacing the capicators is usually a cheap fix but if you do not want to or cannot solder the capicators or if you do not spot any bad capicators, just replace the whole power supply board. This can be done by just unscrewing it off the LCD panel, disconnecting the connections to and from the board, replacing the new board, reconnecting, and screwing back in the new board with the same screws.
Oct 16, 2009 | Sharp LC-19SK24U TV
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1 Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
