Question about Kobalt 120 PSI Electric Air Compressor KL-12
Kobalt 120 psi electric air compressor - Kobalt 120 PSI Electric Air Compressor KL-12
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Oil capacity of kobalt 80 gal air compressor
You could do a little searching on the web, and answer your own question. You can buy a manual for $4.95 at:
http://www.needanownersmanual.com/product_info.php?cPath=21_30&products_id=549&osCsid=tks6fj36b6skq8h7m155hh8kb1
But worse, you don't even need an answer to this question. Simply add oil until level is about half-way up the sight glass. And don't overfill. How simple is that?
Feb 08, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
What oil should I use if Hitachi oil isn't avalible?
On your next trip to Lowes look for Kobalt air compressor oil in the tool department. It sells for under $3 and works great for normal use. They also have Kobalt synthetic compressor oil for extreme conditions and longer use between oil changes. Sell for about $7. I also used Hitachi synthetic oil #19210b 8oz about $8 but hard to find. Kobalt synthetic costs less and works. Good luck.
Aug 02, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Kobalt air compressor will not go above 80PSI
if this is an older or much used unit, cylinder/piston may be worn, unable to push higher psi, which would explain no leaks. if newer unit, seems like regulator unit/valve faulty
Jul 24, 2009 | Air Tools & Compressors
Kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Jul 23, 2009 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Kobalt 120 PSI Electric Air Compressor KL-12 Logo
52 people viewed this question
Top Kobalt Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Kobalt Air Tool and Compressor Expert? Answer questions, earn points and help others
