Question about Ardisam Garden
How do i remove the wheels from the 6070S tiller to repair a flat tire
4 Suggested Answers
  • 22 Answers
SOURCE: How do I remove the wheels on a 1985 Troy Built Horse Rototiller?
Horse wheels are held on with a single roll pin. Pound out the roll pin and pray.....that the rims aren't rusted to the shaft. If the rims are rusted to the shaft, you have two choices. You can either put the new tires or tubes on the rim with the rim on the shaft...or you can work at getting the rims off the shaft. If you put tubes in, be sure the rim is free of sharp edges.....or you'll be sorry.
To get the rims off if they're rusted on, I've used a variety of techniques over the years. The most effective is to weld a nut on the spot where you removed the end caps. Use a nut that's the same thread as your bearing puller. Then use the bolt from your bearing puller to put pressure on the end of the shaft, pulling the rim off. A torch helps, but be careful or you'll be putting new seals in too.
Posted on Jun 14, 2009
bohardin
  • 13 Answers
SOURCE: I have a Gilson Bros. Rear Tine Tiller. I need
check and if the end off axle has a swelled place use a file or sand paper to smooth it out.try some penetrating oil that will help
Posted on Jul 12, 2009
SOURCE: need oil for 6070s scott tiller
my manual says 00 grease 18-22 ounces my model is 6070s hope this helps jlay777_99@yahoo.com
Posted on Dec 05, 2011
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
I need help finding a manual for a rear tine scotts tiller model 6070s 6.0 Tecumseh motor
tecumseh motors might have something for thier power unit. scott migh thave some thing for thier tiller might be a generic machine made by different manufactures with only slightly different paint ect
Aug 12, 2014 | Garden
try googling find a discussion forum some one might be able to help by posting a link or pictures
I need to no the belt size for the v belt on a scott rearline tiiler the model number is 6070s
This is what I found
Forward belt is a 1/2 by 27 (L4270 or 4L270, Oregon 75-427 )
Reverse belt is a 3/8 by 30 (L3300 or Gates FHP 3300)
May 30, 2014 | Ardisam 5.5 Hp Rear Tine Rototiller
How do u remove the tire off a rear rotiller
Remove the pin that secures the wheel to the axle and remove the wheel. Sometimes the wheel will become rusted to the axle and can not be removed. Its best to leave it be. Attempting to beat the wheel off the axle runs the risk of causing internal damage to the transmission.
Once the wheel is off, remove the valve and release the air then using your tire tools remove the tire.
Sep 20, 2012 | Troy Bilt Mtd Tiller Wheel Tire 480x4008
Need oil for 6070s scott tiller
Nov 09, 2011 | Ardisam 5.5 Hp Rear Tine Rototiller
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
Can not get the back tire off
It probably is welded on - with rust.
Spray some WD-40, or something on the axle (on both sides of the wheel). If it still wont come off, you will probably need a puller.
*If your wheels have 2 holes in them, you can make a puller out of a piece of metal and a couple of bolts.
May 17, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
128 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
