Question about Carrier 38CKC042 Air Conditioner
Problem with hunter thermostat
Where do i connect the red jumper wire to. i took thermostat off cause airconditioner wasn't working and the red jumper wire was just laying loose
  • 3,361 Answers
RC and RH get a red wire.
Posted on Apr 23, 2009
Not working
"G" terminal is for the fan, typically using a green wire. "C" terminal is the common, basically a ground, typically using a blue wire. Also, leave in the jumper between "RH" and "RC".
May 19, 2010 | Hunter Fan Company 5/1/1 Programmable...
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have a Red, White, Blue and Green wire , need to wire a Hunter B01 MOdel or 44110 Thermostat has the following ports available G, RC, RH (RC & RH Have a jumper between them), Y/O, W/B, Y/1
From what you describe you have a heat only system with no AC. If that is so, then you would wire it as follows.
Red wire = RC (leave the jumper in place)
Green wire = G
White wire = W/B
Blue wire = is unused because the thermostat is battery powered and does not require a common wire.
I reccomend you consider not using the Hunter T-stat. They are so extremely problem prone and unreliable. You will be much better off with a Honeywell or White Rodgers T-stat.
You will also need to program the Hunter T-stat for your system per the instructions.
Oct 04, 2009 | Heating & Cooling
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Carrier 38CKC042 Air Conditioner Logo
120 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
