Question about Carrier 38CKC036 Air Conditioner
I took a Carrier air conditioning unit model # 38ckc036340 apart and painted it. I drew a diagram as to where all the wires were connected and when I went to put it back together I could not find the diagram. Can anyone please help? Thanks, Ron.
3 Suggested Answers
wise_jf
  • 66 Answers
SOURCE: wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
Posted on Jun 30, 2010
wise_jf
  • 66 Answers
SOURCE: Im looking for the specs on a Carrier air
here ya go
www.xpedio.carrier.com/idc/groups/public/documents/.../38ckc-c2w.pdf
Posted on Jul 02, 2010
What is the tonnage of my carrier AC unit model number 38ckc036340
Most likely a 3 ton judging by the "36" in the number. This is pretty standard in most all cases.
Jul 27, 2017 | Carrier Heating & Cooling
My Air-conditioning have a carrier model no.42SD7B is problem coming error code E 03 what the problem my Air-conditioning please give me answer
Error code should have a description of Of a part or sensor next to the wiring diagram behind a panel on the unit what is it doing or not doing clean the coils change the filters check line and transformer voltage
Aug 28, 2016 | Carrier Heating & Cooling
Carrier model 38tdb air conditioning unit kicks out the 40 amp breaker. Also moisture under compressor unit outside. What is problem?
What breaker? The breaker for the condenser? Likely have a compressor shorted to ground or drawing locked rotor amps. Easiest way to tell is make sure breaker off, unhook compressor wires from contactor. Turn on breaker and turn on machine. If the breaker does not trip, obviously problem with compressor
Jul 14, 2016 | Carrier Heating & Cooling
38ckc036340
If its a Carrier unit from what I could tell looking at their website, all the unit is , is a standard central AC unit
Not a heat pump
Nov 12, 2013 | Heating & Cooling
Where can i get wireing diagram for my carrier central air conditioner model 50zpa
www.xpedio.carrier.com/idc/groups/public/documents/.../50zpa-1pd.pdfFile Format: PDF/Adobe Acrobat - Quick View
The 50ZPA unit is built in one basic cabinet size and features a ... sheet metal and makes the 50ZPA units lighter than other .... Engineers' Specification Guide . ...
Aug 24, 2011 | Carrier Heating & Cooling
Im looking for the specs on a Carrier air conditioning unit model no. 38ckc036340
here ya go
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Schematic diagram of central air conditioning
Several types out there. 99% of them use the same basic wiring.
Red is power from transformer to t'stat. Sometime there is a wire for common from transformer to t'stat too, but not always.
While is for heat. Green is for fan. Yellow is for cooling.
These 4 to 5 wires go on the terminals that are maked with letters: C=common, RH/RC is for power, W=heat, Y=cooling, G=fan.
In most cases, 2 wires from the indoor unit will go to the outdoor unit to power it for cooling. Usually connected to the yellow wired, Y terminal and common or grounded to the unit if the transformer is done in the same fashion.
If you have a heat pump, totally different animal and different wiring too.
Hope this helps you. Good Luck.
Dec 19, 2009 | Carrier Heating & Cooling
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
49 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
