Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60PP9202 No Color
I have a Phillips 60PP9202 and every once in a while the color goes completely out. When I say completely, I mean it goes to black and white. Already replaced the convergence IC chips for a previous problem, but this had happened before they were replaced.
  • Paul Welch
    Paul Welch Sep 25, 2007
    Doesn't happen all the time, and usually only lasts for a few seconds. Screen kind of flickers then goes back to full color.
  • Paul Welch
    Paul Welch Oct 01, 2007
    Hasn't happened since my last post, but I would like suggestions if it decides to happen again.
  • 979 Answers
Bad chroma processor or related component....accordianman
Posted on Feb 26, 2008
I have a Phillips 60PP9202/17F rear projection TV. its getting worn. The overall picture seems to have a slight haze and also seems to have lost the color contrast. yellows and whites are very similar and...
Thats most likely a CRT coolant issue where you will need to remove and replace the coolant in the CRTs ( picture Tunes) Thats a very common problem with Phillips rear projection. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for a 3 CRTs and the CD with instructions.
Jul 22, 2011 | Philips Televison & Video
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
I have a dptv305f phillips tv and the color is almost foggy and it seems like the colors are really green or red
Very common problem caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit at www.tvrepairworld.com which also comes with instructions.
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
My game appears in black and white instead of color.
Ironically enough,I have serviced a Philips that has that problem,and the sticker that portrays the component/composite inputs were wrong and the jack coloring was wrong as well. dont be afraid to try different combinations as for what jack goes where
May 28, 2009 | Philips 47 in. LCD HDTV
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202
Did you replace the Convergence Resistors at the same time?
If not you need to replace them also.
Nov 16, 2008 | Philips 60PP9202 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
