Question about RoadPro RPPS-550 4 Noise Cancelling CB Extension Speaker with Talkback
RoadPro 550
Has 2 wires coming out of back i know the black is for the external but what is the red wire for
2 Suggested Answers
protek480
  • 1714 Answers
SOURCE: trying to find out what gauge of wire i need for a
At 12 volts DC it will pull 125 amps at full load of 1500 Watts.This requires at least #2 copper AWG
Posted on Jul 15, 2009
How do I connect a 5 wire digital Volt/Ampmeter from my solar panel to my battery.
If you can identify which is the voltmeter and which is the ammeter, it should be simple. Say the solar panel has output wires of Red (positive output) and black (negative output). The ammeter goes in series with the load (cut the red wire and insert there). Voltmeter goes between Red (solar panel side usually) and Black. That accounts for four wires. The fifth wire may be an earth ground but I'd be guessing. If you can post a link from the manufacturer, I will comment further.
Oct 09, 2014 | RoadPro Road Pro 12 Volt Dc Portable...
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
I have 2 wires coming out of the back of the roadpro rpps-550 speakers. My question is which one goes to the radio?
Both, black to black and red to red, or use the color coded plugs that may be in your units. If there aren't any, try either way; it won't hurt the speakers or the radio.
Sep 13, 2010 | Radio Communications
Hotpoint ultima. recently changed belt but now have an error e02 coming up, any ideas on how to fix
Hiya,
F02 is a motor related fault, the correct terminolagy is; motor tacho open/short circuit, check motor/wiring and connections.
The most common reason for this is a bad connection or broken wire or last resort, module.
Remove the lower back panel and you will see the motor wires (white plug) there will be 7 wires, 2 of which are red or black, pull gently on the wires at the motor end, you will probable find one of the red/black wires will come off...
If they are all tight, check the external wires in the motor especially the ones that go to the rear of the motor (tacho) inspect those wires for damage..
Another common one is where the wires plug into the motor, this plastic holder sometimes comes loose and hangs from the motor, if this is the case, secure it back to the motor.
Hope this helps, Please rate my help. Thanks
Regards
Sussex engineer
Oct 21, 2009 | Hotpoint Ultima WD72 Front Load...
It wont start!!!
see for the electrical switch is working properly some time the contact might make a issue for it. but there is one issue with the problem you mention that there is red & black wire but where exactly are this wire located in the motorcycle till then do refer & let me know till then see you sir...!
May 24, 2009 | 1981 Suzuki Gs 550 L
How to hardwire to HD motorcycle
Black or ground to chasis, Red to battery if you want it to have power all the time.
To the fuse box to a switched line if you want it to turn off with the bike.
Be sure to have a fuse in line with the power wire to prevent damage to the GPS umit or a fire on the bike.
May 23, 2009 | Garmin zumo 550 GPS Receiver
External speaker connection problem
you will have to solder a female plug to those wires then you will be able to plug in a 1/4th male plug from your speaker wires
Apr 09, 2009 | Standard Horizon GX1255S 2-Way Radio
RoadPro RPPS-550 4 Noise Cancelling CB Extension Speaker with Talkback Logo
50 people viewed this question
Top RoadPro Radio Communications Experts
eradiostore
eradiostore
Are you a RoadPro Radio Communication Expert? Answer questions, earn points and help others
