Question about Homedics Health & Beauty
MatMassager Model MM-100H adapter lost, what is the correct output voltage adapter for this product?
SOURCE: ac adapter voltage
Usually it is 5 Volts and 12 Volts Generally also it is DC not AC. on a standard connector for the power it is 12V 0v 0v 5 V. Hope this helps
Posted on Jan 30, 2008
SOURCE: Need power adapter for an SP-645ME-A1, MODEM ADSL 645ME-A1 Sprint
Found the answer on DSLDepot.com.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: What is the DC voltage, current, and polarity of AC adapter
Howya mate , i wouldn't use a adapter which your not 100% sure belongs to it , even something you'll have the right connection and the right voltage on the plug it will still fry the chip or electrics cause the designers of the item designs adapters in such a way the voltage might be the same but the current is altered and that's why you have to buy a replacement adapter at double the price.
Posted on Aug 19, 2009
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
SOURCE: Toshiba Satelite L200 Laptop, Model PSMCCL-00Y004
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Posted on Dec 24, 2010
Charger output voltage and amp
Search google for a charger for your laptop model and look at the specifications shown for the chargers available. The voltage may also be on the bottom of the laptop and also on the battery pack.
Jun 28, 2016 | Computers & Internet
I have a sharper image Power Tower 200 and I lost my power adapter I need to know what the voltage is so I can buy another one the voltage on the output
On 2000-10-30, the Consumer Product Safety Commission (CPSC) publisheda recall regarding Sharper Image Power Tower CD Rack due to a potential fire & burn hazard. This product sold new for about $160.
Just found this on the net, so it's a good job you lost it!
Apr 28, 2016 | Sharper Image Audio Players & Recorders
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
No ac power
Sounds like you need a new AC adapter? Contact the manufacturer or look at the model number of the AC adapter and search the internet. Otherwise you could try mouser.com or some other site that sells adapters and make sure you have the correct input and output voltages(also correct AC or DC output) current rating equal to or greater than the original. Finally the plug needs to be the correct size, 2.1mm, 2.5mm, etc.
Apr 27, 2014 | Audio Players & Recorders
I have a turntable with a connect that has a double male (large size) connector but a Base which wants a single small male to fit the AUX input. Is there an adapter I can use?
I assume you mean that the turntable uses 2 RCA output jacks and the Bose shelf system has a 3.5 mm AUX input jack. Since you have the RCA audio cable, get a RCA F/F to 3.5 mm adapter. Here is a link to one: http://www.cyberguys.com/product-details/?productid=21319&rH=1601 . If you want to just have a single cable, RCA M/M to 3.5 mm M audio cables are available, http://www.cyberguys.com/product-details/?productid=2706&rH=1095 . If you have 1/4" outputs on the turntable, you need to get a different adapter or use a combination. I don't know of many vendors for the 1/4" adapters these days.
I hope this helps.
Dec 15, 2013 | Bose Audio Players & Recorders
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
Ac adapter
If I understand your description correctly, you have two TVs that use the same model adapter, and both adapters have failed. In that case, I would suspect a weak design, or you may have put them in some place where they were overheated or zapped by power line surges. If it appears to be a design problem, you may want to consider using a substitute.
The adapter should have the output voltage and current marked on it, for example, 12VDC 2300mA would be a 12 Volt, 2.3 Amp output. The polarity is usually marked with a diagram showing whether the center in or hole in the plug is positive or negative.
You can use an adapter with the same voltage and plug style (including polarity) and the same or greater current output. If you find one with the right voltage and current, but the wrong plug, you may be able to change the plug. Just be absolutely certain you have the wires going to the correct terminals; reversing the polarity could damage or destroy your TV. Do a proper solder job on it; simply stripping the wires and twisting them on will not be reliable.
Sources for adapters include www.jameco.com and www.mouser.com.
Dec 13, 2008 | Televison & Video
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Sep 03, 2008 | Gyration Ultra Cordless Optical Mouse
Health & Beauty Logo
101 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
