Question about RCA CC6251 VHS-C Analog Camcorder
Wont recognize any tapes inserted
Here's what happened...I bought the camcorder at a yard worked ...till I got it home...then the battery went dead. I went to eject the tape...only , the tape wont come out...(at the time I did not realize that the thing wont open without the battery)..So, Like an idiot I stuck a screwdriver into the tape locking mechanism...I got the tape out..but wont recognize when a tape is in.
  • azreil Sep 25, 2007
    Is there a part# for the sensor? If one exists..I may be able to order a replacement. Thank you for your reply and assistance.
  • 752 Answers
Sounds like you broke the sensor. Not exactly a DIY fix... It'll probably run around $50-80 to repair it.
Posted on Sep 25, 2007
I just bought a dancing Santa at a yard sale. I was told it worked , so I didnt try to make it work before I left the yard sale. But I got it home and I turned it on and it wont work. does it run on...
Check the bottom or the back of the doll, if it runs on batteries, which most items do, then they will be located in either of these spots.
If it doesn't run on batteries, then it will need an adapter in order to work.
Aug 13, 2011 | Toys
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
When tape inserted re insert tape and C 31:23 APPEARS
The camcorder has detected an issue that may require a power reset. To perform Power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 04, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
When trying to record
You need to check the small switch on the tape and switch it the other way.
Feb 26, 2008 | JVC GR-D244 DV Digital Camcorder
Won't work with tape installed
I had this same problem. At my wedding, and didn't get to record it because of it. When I got home I put a new tape in and worked fine. It was just a bad tape.
Oct 27, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Video Cameras Logo
105 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
