Question about HP Pavilion dv7-1129wm Notebook
Internal battery error 601 is displayed what is solution
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
It looks like your battery is at low capacity.
Battery CheckPrimary Battery Replace601This indicates that the primary battery has very low capacity. See Testing and Calibrating the Battery (Windows 7) or Testing the Battery (Windows Vista) for details on using the HP Support Assistant to verify the battery capacity and, if necessary, order a replacement.
This article was pulled from HP's support webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443317&cc=us&dlc=en&lc=en#N266
It may be time to replace your battery.
Good Luck!
Posted on Oct 22, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
1. This error is about the primary (main) battery, not the small CMOS one..
2. You may remove the primary battery from the laptop and use the laptop as a desktop using only a power cord. The battery doesn't have to be installed in the laptop and the error shouldn't be coming back then..
I would upgrade the BIOS first, it could be a bug and a newer BIOS might fix it..
Posted on Oct 16, 2013
4 Suggested Answers
  • 8909 Answers
SOURCE: I have an HP Dv7-1133cl that is giving me a error
It is called the Cmos Battery and if you browse www.insidemylaptop.com you will find how to change it.
Hope that helps.
Posted on Dec 31, 2010
  • 6771 Answers
SOURCE: hp dv7-1245dx error 601
Go in to bios and reset to factory default.
Posted on Mar 27, 2012
  • 6771 Answers
SOURCE: internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Posted on Jun 16, 2012
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Internal battery 601
Replacing the bios battery will fix that.
Jul 14, 2014 | Computers & Internet
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Laptop hp Compaq 6530b alerting battery code error 601
Thats the internal battery fail.
You must replace the internal battery (CMOS Battery / BIOS Battery)...
Oct 13, 2013 | Compaq Computers & Internet
601 internal battery error
Replace the battery. See utube for video instruction; type in your model and 'CMOS battery replacement', in the search box.
Jul 11, 2012 | HP EliteBook 6930p Notebook PC
Internal battery error 601 hp compaq 6735s laptop
Jun 16, 2012 | HP Compaq 6735s Notebook
I have internal battery 601 problem need new battery message. when i turn on it boots up then before i can check the external battery level it switches off. So i start again with mains plugged in and the...
This is the bios battery which back up the clock and settings and it is normally found on the main motherboard accessable from the rear of the laptop from the memory card opening.
so remove and fix the 3 volt battery into the slot.
Sep 28, 2010 | Computers & Internet
HP Pavilion dv7-1129wm Notebook Logo
166 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
