Magnavox tv 39me413vf7 why it takes so long for tv to come on
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ...
tv.manualsonline.com > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Program codes for Magnavox TV model 27ms4504/17
If you have an orifginal Magnavox remote, you don't need any program code to use it. If won't work, it's because you should take it to repair.
May 23, 2015 | Magnavox Televison & Video
I have a RCA Universal RCU430-needcode for Magnavox TV
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jun 03, 2009 | RCA Universal Remote Control
My magnavox tv has no remote and it has child lock how to unlock?
take ur tv to someone local who fixes tvs. they will have a magnavox remote. use the remote and press tv/av simultaneously pressing enter
Apr 16, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up.
After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Jan 14, 2009 | RCA RCU404 Remote Control
Set child lock on magnavox tv and i dont have a remote to turn it off, help
take ur tv to someone local who fixes tvs, they will have a remote for a magnovox. tell them to use the remote and simultaneouisly press tv/av and enter.
Jan 01, 2009 | Philips Magnavox 27MS343S 27" TV
Need to program a universal remote but cant turn on tv
take ur tv to a local tv repairman, they will have a magnavox remote. use it and simultaneously press tv/av and enter
Dec 14, 2008 | Philips Magnavox 27MS343S 27" TV
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Tv has child safty lock on cant turn on to program remote
take ur tv to a local tv repairman, they will have a magnavox remote. use it to simultaneously press the tv/av button and the enter button.
Dec 28, 2007 | Philips PH-BIG3 Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
