Question about Texas Instruments TI-83 Plus Calculator
What is the pH if {H^+}=10^-7 - Texas Instruments TI-83 Plus Calculator
-(log 10^7) pH=7.00
Posted on Apr 28, 2009
Ph calculation
Number of moles [H+] in first solution =concentration of [H+] in mol/L times the number of liters. [C1]=10^(-pH)=10^(-3) mol /L
Number of moles N1=10^(-3) mol/L * 1L= 10^(-3) mol [H+]
Concentration [C2] of second solution
[C2]= 10^(-5.5)=3.16227766*10^(-6) mol/L of [H+]
Number of moles of H+ in second solution
N2=[C2]*10 L =31.6227766*10^(-6) mol of H+
Total number of moles H+ in the new solution
N=10^(-3) +31.6227766*10^(-6) =1.031622777*10^(-3) mol
Concentration of H+ in new solution
[C]=1.031622777*10^(-3) mol / (1+10) L=9.358388878 *10^(-5) mol/L
Resulting pH=-log( 9.358388878 *10^(-5) =4.02787
pH is 4.03
Jun 15, 2014 | Office Equipment & Supplies
How do I calculate inverse log on this calculator? Let's use -pH=-7.41
To get the concentration C of hydronium ions use the relation
C=10^ (-pH)=10^ (-7.41)=3.89045*10^(-08) or just C=3.89*10^(-8) mol / L
The inverse of the function log in base 10 is 10 to the power of.
pH=-log(C) and C=10^(-pH)
Jul 21, 2011 | Casio FX-115ES Scientific Calculator
When I go to use the 'log' button on TI 30XA I do not come up with the same answer as in my course book (for the examples) No real instructions on logs in the little instruction book. Have tried...
You calculate the pH with the relation
pH=-log(c) where c is the value of concentration in mol/L.
ex: c[H+]= 3.57x10^(-6)
pH: (-) [LOG] 3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press [(-)]
If you have the pH, and want to calculate the concentration that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
May 17, 2011 | Texas Instruments TI-30XA Calculator
How do I calculate pH from H+ concentration on a ti 30a? [H+] 1.2 x 10 -5 M = ? pH = 4.9 I worked out pH to concentration but struggling for the opposite figured it out once and...
c= 10^(-pH)
Ex pH=8.23
General shortcut.
May 20, 2010 | Texas Instruments TI-30XA Calculator
How do i calculate the pH of a solution on the casio fx-260 solar calculator?
General shortcut.
If the concentration is of the form 1* 10^ (-a) where a is an integer between 0 and 14, the pH is given by a.
c= 1.* 10^(-5), pH=5
c=1.*10^(-11(, pH=11.
For other values, ex: c=3.68 *10^(-8)
pH: 3.68 [EXP] [+/-] 8 [LOG] [+/-] Result is 7.434
Above, the [+/-] key is the change sign key, just above the [7] key.
Mar 13, 2010 | Casio FX-260 Calculator
I am trying to get the inverse log from 1x10-4.62
I suggest you reformulate the question. If you are doing pH questions, give the pH and we will show you how to get the concentration. Alternatively, give the concentration and we will show you how to obtain the pH. Keep in mind that in the context of pH questions, pH is restricred to the interval [0,14], and that imposes restrictions on the possible values of the concentration.
If c=concentartion, then
pH=-log(c)
This is equivalent to
c=10^(-pH)
Assuming that this is what you want to do (ie. calculate the concentration)
Press [2nd][log] to access the 10^ function
Screen displays 10^(
Enter the change sign [+/-]
Enter the pH value 4.62
Screen displays 10^( -4.62)
Press [=]
The result is 2.398832919E-05. To 3 significant digits the concentartion is c=2.39E-05 mol/L of H+/H3O+ ion
Mar 07, 2010 | Casio FX-115ES Scientific Calculator
I am having trouble doing pH solution problems on my TI-84. I'am trying to figure out if I am entering the problem wrong or what the problem is.
Let us start with the definitions:
Let c be the concentration of H+/H30+ ions in the the solution (expressed in mol/L).
By definition the pH =-log(c)
Rewriting the equation as log(c)=-pH
Taking both members of the last equation to the power of 10
10^(log(c))=10^(-pH)
Since 10^(log(x))=log(10^x)= x (identity for inverse functions)
we get c=10^(-pH).
To handle concentartion-pH problems, you have two relations, namely
pH=-log(c) : to calculate pH from the concentrartion
and
c=10^(-pH): to calculate the concentration from the pH
A SHORTCUT WORTH REMEMBERING.
If you concentration is of the form c=1.*10^(-a) where a is between 0 and 14, the pH is simply the value of a.
Ex: c=1.*10^(-3), pH=3
c=1*10^(-8), pH =8.
Now let us take a more general example: c=6.54*10^(-9), pH=?
pH=-log(6.54*10^(-9))
You have to enter twice the change-sign [(-)], the one on the bottom row of the key pad.
Here is a screen capture from a TI84Plus calculator.
As you can see, you can use the general power key [^] to enter 10^(-9)
or the shortcut [2nd][ ' ] to access the (EE) which appears on screen as E. The second way is more efficient (left screen)
On the screen to the right you will notice that I did not close the parentheses, yet I obtained the correct result. However, I suggest you always close parentheses to avoid syntax errors.
Feb 11, 2010 | Texas Instruments Office Equipment &...
How do i enter pH on a TI 30 calculator
This post answers two questions
  1. How to obtain the concentration knowing the pH?
  2. How to obtain the pH knowing the concentration
If you are not interested in the theory, jump to the examples at the end of the post.
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Examples
1. Let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Calculating the pH
Shortcut:
For all H+/H3O+ concentrations of the form 1.*10^(a) where a is an integer number between 0 and -14, the pH is the negative value of the exponent.
Concentration =10^(-3), pH=3
Concentration=10^(-11), pH=11
For other concentrations such as 3.567*10^(-8), one cannot use the shortcut above, but have to calculate the log of the concentration
[H+/H3O+] = 3.567*10^(-8)
pH= - log(3.567*10^(-8))
This is keyed in as follows (to minimize the number of parentheses)
8 (-) [2nd][10 to x] [*] 3.567 [LOG] [=] (-)
Here you have two (-) change sign, the first is entered after the exponent of 10, the other at the end of the calculation to take the negative of the displayed result. You may notice that it is entered in the reverse order of the defining relation - log(3.567*10^(-8)).
To verify your calculation, the result is 7.447696891 or just 7.45
If you have a problem with the first (-) try entering it before you type in 8.
Hope it helps and thank you for using FixYa
And please, show your appreciation by rating the solution.
Dec 07, 2009 | Texas Instruments TI-30XA Calculator
How to use antilog?
[H+]=10^(-pH)
Exemple: let the pH=5.5, what is the H+ concentration?
Hope it helps.
How do i use the inv log for calculations on my sharp el-531wh
Let y=10^(x) 10 to the power of x
Take the log of both tems of the equality. You get
log(y)=log[10^(x)] where I used square brackets for clarity. But from the general properties of logarithms
log(b^(a)) = a*log(b)
Applied to our expression above
log(10^x)=x*log10
But since we are using log as log in base 10, log_10(10)=1
so
log(y)=x
We thus have two equivalent relations
y=10^x <----> x=log(y) The double arrow stands for equivalence.
If y is the log of x, then x is the antilog of y
Your question: With log_10 standing for logarith in base 10
pH=-log_10(c) c= concentration
Then log_10(c)=-pH the equivalence above translates as
log_10(c)=-pH is equivalent to c=10^(-pH)
The concentartion corresponding to a pH of 7.41 is
c=10^(-7.41)=3.89x10^(-8)
You enter it as follows
10[^]7.41[(-)][ENTER/=]
Hope it helps
Aug 09, 2009 | Sharp EL-531VB Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
