Question about Dryers
Codes for whirlpool cabrio mine says CF 01 - Dryers
4 Suggested Answers
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool cabrio is giving a code which is f1,
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 20, 2010
What is F- 01
Is this for a Whirlpool Cabrio Dryer? Which model?
F-01 means Primary Control Failure
F-01 flashes when there is a primary control
failure. Replace the machine control electronics.
Jun 30, 2014 | Whirlpool Dryers
Code f1
F-01 on a cabrio is a primary control failure.
Replace the machine electronics PCB (primary Controller Board)
Nov 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio whirlpool washer and a F1 code keep's on coming up what doe's it mean
i just called on mine for the f1 code and they said its a defect and would fix it call 18002531301
Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Need latest codes for pure ntl please
NTL 54 01] 07/05/09
00 = 5C 2C 26 36 CF 81 AB 66
01 = 2C 10 35 AC 06 57 BE 6F
May 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes update
00 = AA B7 D1 D9 CE 8E 83 AF
01 = 8E 80 D7 EF 44 93 02 2B
NTL 54 01] 07/05/09
Anyone got the new starview codes for ntl uk mine gone off today
NTL -- 18/02/09
54 01
00= 5C 2C 26 36 CF 81 AB 66
01= 9F 09 00 66 3B D2 43 8B
Feb 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
I need codes for telewest 5a 01,27 th nov 10:30 am
e8/25/93/b2/6a/90/0e/a2
16/cf/0c/a7/a7/14/d2/22
27/11/08/t/w/v/m/s/v
Nov 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
