Question about Proscan 32LB30QD 32 in. LCD TV
Model PLCD3283A won't turn on - Proscan 32LB30QD 32 in. LCD TV
Need a tv sensor for Proscan Model PLCD3283A
Sorry we do not sell part here, that said there are lots of online suppliers of parts for TV's and all electronics
Jun 26, 2017 | Proscan Televison & Video
My proscan plcd3283a won't turn on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ...
Apr 08, 2017 | Proscan Televison & Video
This is the second Proscan that the volume breaks within 2 years of purchase. Is this a common occurance with proscan PLCD3283A?
Check the speakers first. If it found OK, check and replace the damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. This fault can occur to any brand TV at anytime. http://electronicshelponline.blogspot.com/
Mar 02, 2017 | Proscan Televison & Video
Replaced the main board for dead tv she works now but picture looks solarized thought i could go intp factory mode an swotch panel types but cant get into factory mode any ideas???
Check your lvds, connections or the flat cable that goes to your main and tcon that's connected to the panel as well. Take out and clean the cables connections
Feb 07, 2016 | Proscan LCD LED TV REMOTE CONTROL For...
Won t turn on
What model is it ? Explain "Won t turn on ".
Aug 31, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Jun 20, 2013 | Vivitar Cameras
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
Proscan 32LB30QD 32 in. LCD TV Logo
106 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
