Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
SQD26VW AMANA STOPS COOLING AT THE TOP,BOTTOM SEEMS TO BE COOLING AND WHEN PROBLE ACUURS THE WATER STOPS
SQD26VW AMANA WILL STOP COOLING AT TIMES.I NOTICED THAT THE BOTTOM IS STILL COOL.THE TOP OF EITHER SIDES OR NOT.I REPLACED THE DEFROST TIMER AND YOU CAN TURN IT AROUND AND A LOWER FAN WILL TURN ON.BUT THE INSIDE FAN AT THE TOP WILL NOT.NO ICE FOUND AND WIRES LOOK GOOD.COULD THIS BE A RELAY LOCATED NEXT TO THE COMPRESSOR,DOES IT OPERATE THE FAN.I ALSO NOTICED THAT THE FREEZER DOOR DOESN'T SEEM TO SEEAL ALL THE WAY BUT THAT HAS BEEN THE CASE PRIOR TO THIS.ANY IDEAS?
  • Ron Geddings Apr 27, 2009
    Yes I installed the part and it worked great.
    Thank you so much for your help.I could see what you meant by it freezing and expanding the thermostat had sqollen at the top and it was the problem.
    Thanks again
    Changed.excellent rating.Thanks again for your help !
    President:
  • 331 Answers
Hi R,
Based on your description, the defrost limit has failed and should be replaced. The job takes about 30 minutes. The part you'll need is a WR50X55. You can find it online by plugging that number into a search engine, or pick one up locally at an appliance parts retailer.
UNPLUG THE FRIDGE BEFORE CONTINUING!!!
Clean out all the stuff in the freezer and remove the shelves. Then remove the panel in the back of the freezer section. You'll see the defrost limit clipped to the evaporator coils at the top right. Remember which tube it's clipped to, then take it off the tube.
Now clip the wires close to the limit and remove the limit. Strip those 2 wires back about 3/8" and connect them to the new limit one wire at a time. Cap these wires off with wire nuts. All you gotta do now is use one of the clips in the kit (I use the "U" shaped one, NOT the "W" shaped one) and clip it to the tube you removed the old one from. Rebuild everything and plug the fridge back in. That's it!
NOTE---> The fan inside the freezer will NOT come on immediately. The derfrost limit you just installed must get below 55 degrees first, then it'll turn the fan on. OK?
If there's anything else I can help you with, please write back. If not, and this has fixed your problem, please rate me.
SG
Posted on Apr 23, 2009
  • Tracy Farrell
    Tracy Farrell Apr 23, 2009
    Another thing, R.
    The reason it was an intermittent issue is this. The defrost limit is supposed to be completely sealed. Well, your old one has blown its' seal. When this happens (and it happens to Amana ALL the time) moisture gets into the limiter. This moisture obviously freezes and when it does, it expands. This expansion forces the seal open even more which allows more moisture thus more expansion... over and over 'til the limit eventually gives out altogether.
    The limit I pointed you to is made by G.E. and it's a universal part for all domestic refrigerators. I have never had a "call-back" on one that I have installed. This one is a reliable limiter and you won't have this issue occur again.
    SG
  • Tracy Farrell
    Tracy Farrell Apr 27, 2009
    I'm glad you got it fixed! Is there any way you can re-visit the "Rating" page and rate this as "FixYa"? I'd surely appreciate it.
    SG
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Refrigerator is not cooling well
The freezer seems to be ok, there are times when the compressor is not working it seems and the top refrigerator is warm. I thought it may have been that there was too much stuff in the refrigerator, but that does seem to be the problem
Jun 02, 2010 | Amana ARB8057CSL Bottom Freezer...
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an amana model no. sqd26vw and would like to know where i can find the defrost timer. thanks, jim
It is on the back left corner of the frame. Remove the dust cover to locate the timer.
Jun 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Icemaker
Heya,
It sounds like you need a new float for your Ice Machine, there are not that expensive. There are alot of good ice machines out there, just make sure that you get one that you like the look off.
Amana are good units thou.
Let me know how you go
Jan 09, 2009 | Refrigerators
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
812 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
