Question about Roomba Robotic Floor Bagless Vacuum
ROOMBA POWER MY ROOMBA HAS BEEN DOCKED AND I THOUGHT CHARGED. THE POWER BUTTON WILL NOT LIGHT UP AND THE UNIT WILL NOT TURN ON
  • 1 more comment
  • Anonymous Nov 10, 2007
    same
  • bad battery Mar 17, 2008
    received as gift two ? christmas's ago,tried that day and never used.
    Got out of box today and have been charging for 10 plus hrs. do not think it is chargeing. Per box should charge in 3 hrs.
  • Anonymous Apr 19, 2008
    Roomba wouldn't charge so we bought a new battery but still won't charge.
  • 97 Answers
Is the power light pulsing when on charger? Make sure you have the battery in correctly and snapped securely into place. Only charge on the home base, do not plug in directly.
Posted on Mar 22, 2008
Roomba 595 no lights - not charging
Just a idea but have you tried replacing the battery? Here is a link to a forum on this topic.
http://www.robotreviews.com/chat/viewtopic.php?t=2901
Dec 29, 2015 | iRobot Roomba 560 Robotic Vacuum
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    What are these 2 blinking lights on my irobot roomba?
    "The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
    * Pulsing Amber - Charging
    * Green - Fully Charged
    * Amber - Partially Discharged
    * Red - Almost Fully Discharged
    * Flashing Red - Fully Discharged"
    At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
    GREEN = MISSION COMPLETE
    YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
    YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
    RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
    number of beeps after ?uh-oh? :
    No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
    1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
    2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
    3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
    4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
    5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
    6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
    7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
    9 beeps: Sensor error Please contact iRobot Customer Care.
    10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
    place it got stuck.
    Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
    Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
    1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
    2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
    3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
    If this does not correct the problem, please call customer support at 877-855-8593
    Nov 22, 2012 | Vacuums
    The light on my Roomba flashes amber very quickly when plugged in directly with the adapter. what does this mean? it usually flashes slower when docked.
    If Roomba senses that its battery has been significantly discharged, Roomba will enter a special 16-hour refresh charge cycle. When the 16-hour refresh charge is initiated, the CLEAN light will quickly pulse red/amber. Do not interrupt the cycle once it has begun. The 16-hour refresh charge cycle is initiated by the robot and cannot be started manually.
    For long-term storage, always remove the battery from Roomba and store in a cool, dry place. Blue or black batteries should be stored after Roomba has been used. Yellow batteries should be stored after being fully charged.
    Battery capacity reduces overtime and usually the battery will need to be replaced each year.
    May 14, 2010 | Roomba Robotic Floor Bagless Vacuum
    The clean light on the Roomba 520 doesn't quit blinking even when it has been docked for hours, i checked all the plugs and i also pushed the spot button for 10 seconds. it is a a slow continual blink as...
    Sounds like you didn't remove the batteries protective tape. If this isn't a new roomba, your problem may be the charging cycle. For a brief video of what to do click the link below.
    http://irobot-homesupport-en-eu.custhelp.com/app/answers/detail/a_id/980/related/1/session/L2F2LzEvc2lkL3h6RTdvWVdq
    Mar 15, 2010 | iRobot Roomba 530 Robotic Vacuum
    Seems to charge but then wont come on
    Sounds like you bought a defective battery
    You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
    Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
    Roomba starts and stops.
    try pulling the battery out and holding down on the power button for 5 secs. if this doesn't fix the problem--you need a new battery.
    Jun 06, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Roomba cuts off after a minute or so.
    If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
    If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
    May 13, 2009 | iRobot 4150 Roomba Vacuum
    Roomba 4108 does not charge
    Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
    Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
    ROOMBA 415
    It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
    Sep 28, 2008 | iRobot 4150 Roomba Vacuum
    Roomba Robotic Floor Bagless Vacuum Logo
    551 people viewed this question
    Top Roomba Vacuums Experts
    Marvin
    Marvin
    NOEL
    NOEL
    Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
