Question about Targus (AMU02US) Mouse
Retractable Cord won't lock
I have a Targus mouse with retractable cord. The cord winds up fine, but won't lock in place when I extend it out. How do I fix this?
When fully extended (you have to hold the cord in place since it won't lock), slide the rectractable device down the cord until it is butted up against the USB connector. You can use the mouse with no problems like this. When you are done, slide the retractor back to the middle of the cord and the ends will wind back in. It's not a perfect solution but at least makes the mouse usable.
Posted on Sep 08, 2009
Following on to the above solution, I held the full length of the cable out, and moved the retractor just a little, to a new position along the cable. It seems to work fine now. Maybe the cable got slighty deformed in that one spot, and moving it gave it a fresh start.
Posted on Oct 28, 2009
I have a mouse with a retractable cord, but when I go and try to extend the cord, it doesn't lock in place and it shoots back into the mouse. If you could please help fix this it would be appreciated.
the retractor lock is prob broken cannot rely fix them, would just tie a not in cable and it will not go back in then. pull all way out and tie not in cable so its near to the mouse end. its not a fix but it will work the retractor locks don't last on items flimsy plastic. the pins wear out so don't lock.
Jul 27, 2017 | Computers & Internet
Cord won't retract on exectrical cord reel
The most common cause is the the cord has been extended past its limits (fully extended) and can't be pulled any further to pull the latching mechanism far enough to release and allor the winder to do its think. (I used to manually force it to move further by using a screwdriver. Pushed the coil a bit further over (as if more cord was being extracted), just to the point where the latch could release.
There's a troubleshooting guide on the Reelcraft website. Perhaps it can help.
Reelcraft Reel Support Hose will not retract
Jul 28, 2014 | Reelcraft Retractable Triple Tap Electric...
My retractable targus optical mouse keeps turning on and off when I plug it in. How do I take it apart? Model: AMU75US
The problem may be in the actual connectors. Try using a different USB port. If the mouse is out of warranty, you could snip the usb plug off and splice it into another USB connector.
Sep 27, 2013 | Targus Corded Mice AMU75US Compact Optical...
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Jun 03, 2012 | Bernina Sewing Machines
My Targus optical mini-mouse with retractable cord just stopped working.There is no light underneath. Does it have a battery? Or is it just bust?
are your mouse is bluetooth or cable?
if its bluetooth, its definitely need a battery. if its cable then your mouse probably already damaged because there is no light from your mouse.
hope this useful, regard riyan
Mar 29, 2011 | Computers & Internet
What should i do when my mouse doesnt react when i connect it to my mac? thanks :)
try the targus mouse on a different mac or pc, if it doesnt work,you probably have a defective mouse.
Jan 25, 2011 | Targus Optical Retractable (paum012e)...
I need a wiring diagram for a Targus PAUMO1
Not worth it!
One wrong wire could burn out multiple USB ports on your computer (or any computer the device is plugged into).
It would be best to get a new or used mouse.
Apr 24, 2010 | Targus Ultra Mini Optical Mouse With...
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
Is there a way to repair the retractable cord re tractor? I pulled the cord out too far and now it won't retract.
you must disemble ,wind the retractor all the way up then allow to **** the cord in you may have to disconect the cord the recon the cord
Dec 12, 2009 | Cuisinart PSC-650 6.5-Quart Slow Cooker
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Targus (AMU02US) Mouse Logo
1,812 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
