Question about Vacuums
Can't find a hosee kit for it.
Can't find a hose kit for craftsman vacuum mod.338.179370 it has roto-lok on it.
  • 281 Answers
Call sears they should be able to get it.if ot call all-type vacuum and janitorial supply 314-275-8006
Posted on Apr 23, 2009
Why is suction substantially reduced?
blockage in the suction line
if it is the wet mode there should be a valve (ball) that sucks up to stop water from getting to the motor when the receiver is too full. If you are in wet mode and still have the dust bag in place then the bag will be a solid block of mud and that will be the blockage.
May 21, 2015 | Craftsman 17765 Canister Wet/Dry Vacuum
I want to install a new hose on a Sears vacuum Mod #116.23812300. How do I remove the Hose Connection Cover(#4370325)? It appears to be a flexible plastic part, however, it will not move from it's position...
You are trying to remove the flexible hose part from the end correct? If you post a picture of the item that would be very helpful since the numbers you posted really didn't help much.
Usually you can just take a flat headed screwdriver and pry out the old hose from the side of the connection piece. Let me know if I am not understanding correctly and I would be glad to help you.
thanks
May 05, 2008 | Vacuums
How do I get the craftsman 79470 to vacuum?
First check if the bag is full. Then check if hose is clogged or attachment is clogged.
Mar 05, 2015 | Craftsman Vacuums
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Purchased a Pelonis Windowless a/c with two hoses, the hoses are now disintegrating. Where can I purchase new ones?
i have a craftsman tractor and when we engage the blade it cuts then dies we checked the blades abd the belt nothing is around them
May 17, 2011 | Vacuums
I have a torn hose on my Samsung Quiet Storm should I try to repair or toss it. Mfg no longer makes replacement hose
The early hose on these was prone to tearing. If you are careful you can shorten it once. Beyond that it will become too short to use on the vac properly. This hose was copied from the original Black and Decker hose and power head kit and was likely upgraded by a flex vinyl molded hose which should be more resistant to tearing.
Some vac shops carry hose "refills" and a Samsung dealer may have one in stock even if the hose was discontinued. The vac is good quality in its general design and worth fixing although the original diameter of this hose may be tough to match
Oct 30, 2009 | Samsung Quiet Storm 9069 Vacuum
No suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Oct 03, 2008 | Eureka 411A Upright Vacuum
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Craftsman wet/dry vacuum
my last post was supposed to be a solution.
Jun 21, 2008 | Craftsman 17029 Wet/Dry Vacuum
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
